72 dart speedometer rebuild or electronic upgrade???? #1639844
06/28/14 05:36 PM
06/28/14 05:36 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
my 72 dart speedometer flickers up and down real bad.the speedo will not return to zero unless i tap on the speedo face,i replaced the speedo gear in trans ,as well as the speedo cable.should i have this one rebuilt or can i upgrade it to a electronic controlled speedometer with a sender in trans?????any ideas,
vehicle is 72 dart 318 4 door so its not like its a rare vehicle.
Re: 72 dart speedometer rebuild or electronic upgrade???? [Re: hp340nos] #1639845
06/28/14 07:45 PM
06/28/14 07:45 PM
Neither. rebuilding it would be too much money. Not sure what the electronic conversion would cost but k.i.s.s. Place an ad in the A body parts wanted section here
