stock axle lengths??? #1639657
06/28/14 01:29 PM
06/28/14 01:29 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I have 3 differnt 8 3/4 rears that I have took the axles out and wife has helped me by moving them. I have a e body. A 71 b body. And a 73/74 b body
I know wich housing is wich. But not sure wich pair of axle go to the housings. So I need some help.....housings are bare
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: stock axle lengths??? [Re: toplescuda] #1639658
06/28/14 01:46 PM
06/28/14 01:46 PM
The specs might be in the archives. You could also mockup the axles and I think with the right axles in the right housing you want 1.5" between the ends of the axle splines. Add a bit for what you get for gap for the backing plate/foam/steel gaskets thicknesses & want 1.5" or to k.i.s.s. just slam the brake assy's together with the axles & measure the end gap there in the middle & likely you'll either be close to 1.5 or way off so it shouldn't be hard to get em matched
Re: stock axle lengths??? [Re: RapidRobert] #1639659
06/28/14 02:01 PM
06/28/14 02:01 PM
BDW Offline
BDW  Offline
Re: stock axle lengths??? [Re: toplescuda] #1639660
06/28/14 02:21 PM
06/28/14 02:21 PM
Aren't all three of those the same width I have been warned about swapping axles form side to side, it is a reaaly big NO NO, according to Mark Williams Make sure that all three adjsuters end up on the passenger sides
Re: stock axle lengths??? [Re: Cab_Burge] #1639661
06/28/14 06:12 PM
06/28/14 06:12 PM
Cab what did he say was the problem with that?
Re: stock axle lengths??? [Re: RapidRobert] #1639662
06/28/14 06:27 PM
06/28/14 06:27 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Its like putting used T-bars on the wrong side...your twisting them in the opposite direction they're used to.
Re: stock axle lengths??? [Re: nomore65BelvJim] #1639663
06/28/14 06:54 PM
06/28/14 06:54 PM
Ahhh gotcha that makes perfect sense
