Page 7 of 14 1 2 5 6 7 8 9 13 14
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639442
07/04/14 07:42 PM
07/04/14 07:42 PM
AndyF Offline
AndyF  Offline
Yep, it is pretty funny to think about a car that is traction limited in the first 3 gears with a 2.94 out back. If you put the Passon in there with 3.91 gears it will be traction limited on street tires in the first 4 gears. But you kind of need the extra low first gear in order to load it onto a trailer and stuff like that.
It is basically Hemi power or Viper power in a 3100 lb car. With 427 inches and max ported heads it makes good power. The cam and the carb are both small to help make torque down low. Those can be changed if you want more power. A bigger cam and carb would free up another 50-100 hp depending on how big you went but then you would need the 3.91 gears to launch it.
Re: no talk of Tim's Valiant being for sale here [Re: AndyF] #1639443
07/04/14 08:41 PM
07/04/14 08:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks for the dyno pic Andy!
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639444
07/04/14 09:06 PM
07/04/14 09:06 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
it's WAAAAAY too much for the street that's for sure!
One can get used to it...
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: no talk of Tim's Valiant being for sale here [Re: 68cuda440] #1639445
07/05/14 03:47 AM
07/05/14 03:47 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
So it should be from this point referred to as SCOTT's Valiant.
Re: no talk of Tim's Valiant being for sale here [Re: Kern Dog] #1639446
07/05/14 10:49 AM
07/05/14 10:49 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well, I do own it now but it will always be Tim's, he's the one who put it on the map.
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639447
07/05/14 12:09 PM
07/05/14 12:09 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Congratulations on the purchase again! I say you hold off on any changes and spend all your money on track time and tires/pads. No paint, no gears, no OD tranny. None of that will make it faster on the track.
And one day I'd love to run our cars together. Andy's car has always been the benchmark in my mind. Maybe at AutoXcuda's track day in Cali in a year or two? Or another event? Steve- how much track time should one expect at y'all's road course track day?
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: no talk of Tim's Valiant being for sale here [Re: Uhcoog1] #1639448
07/05/14 12:25 PM
07/05/14 12:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Wade,
Wise words that won't be ignored. I plan on doing a lot of testing at the local Spokane track in it's current configuration just as suggested, two reasons, one to get some fresh seat time since I'm a bit rusty and unfamiliar with the car, and two, to check out the current combo. Andy's input about the trans/rear will also be taken, mostly because I already have the brand new Passon 5 speed and a new Dr. Diff Yukon 3.91 drop in unit so those are no brainers, however I won't be doing either swap until winter down time sets in.
It would be fun to run our cars together, we can work out a plan down the road but I'm open to it, me, you, Steve, and maybe some other A-body guys could have a little shootout, that would be a hoot!
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639449
07/05/14 01:32 PM
07/05/14 01:32 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
That sounds fantastic! Count me in for that shootout.
Track rentals for a half dozen cars or so are usually quite reasonable.
Re: no talk of Tim's Valiant being for sale here [Re: Uhcoog1] #1639450
07/05/14 02:00 PM
07/05/14 02:00 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Wow! Depends on when and where but definitely keep me in the loop! My car still needs some assembly and it is more street oriented but I definitely want to get some track time. I would guess it will be running and driving in the spring.
Michael
Plano, TX
Re: no talk of Tim's Valiant being for sale here [Re: Uhcoog1] #1639451
07/05/14 03:13 PM
07/05/14 03:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
At Spring Fling Speed Festival we run from 8am to 5pm the Thursday before Spring Fling. There is a ton of track time and only two run groups. There's only about 30 cars and it's a big track. Here's some pics and info from this years past event: https://board.moparts.org/ubbthreads/show...part=1&vc=1
In the afternoon you can run in about any run group. So if you wish, you could run almost constant from 1pm to 5pm. You and/or the car will need more breaks than the track availability.
The red Valiant has run at Spring Fling Speed Festival before in 2007. Seriously fast. That is where a water pump belt slipped off resulting in a blown head gasket... IIRC, that situation directly log-rolled into the 427 motor build.
The red Valiant at SFSF 2007...
the Crossfire drove from Alberta Canada. The orange Challenger from Phoenix. The blue 68 Barracuda is now owned by Boydsdodge in Canada (he comes down most the time)...
Real 1969 Winston Cup Nascar Hemi Daytona.
Scott here is a link to pictures from that day you might be interested in: http://www.mrmopar.com/SpringFling2007/WillowSprings/
Re: no talk of Tim's Valiant being for sale here [Re: autoxcuda] #1639452
07/05/14 04:26 PM
07/05/14 04:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Cool thanks Steve! What was the engine combo like before the 427 build?
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639453
07/05/14 04:31 PM
07/05/14 04:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
IIRC, 360 (or 340) with edelbrock heads. Edelbrock heads re-used after port work on current motor.
Re: no talk of Tim's Valiant being for sale here [Re: autoxcuda] #1639454
07/05/14 04:33 PM
07/05/14 04:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok so stock stroke? Man this thing will be a different animal with this stroker. I just took it for a short rip around the neighborhood, little sucker is sure fun to drive!
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639455
07/05/14 04:52 PM
07/05/14 04:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
not just stock stroke, but less heads, less cam relatively, it had 4 piston viper brakes then...
Bob Reed drive it in 2007 and really liked it. He said you can really tell that is has a cage on it. And his personal opinion was that his own 1968 Barracuda was about maxed out chassis-wise without having the roll cage that Tim's Valliant had.
The E-Max Challenger does not have a cage. Seems to do well on track, but really no direct comparison. And Hotchkis is building a new car with with Kevin Wesley...just happens to have an even more extensive roll cage/chassis than the red 68 Valiant.
Re: no talk of Tim's Valiant being for sale here [Re: autoxcuda] #1639456
07/05/14 05:50 PM
07/05/14 05:50 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Is Kevin Westly the guy with the 70 Satellite taxicab looking autocross car?
Re: no talk of Tim's Valiant being for sale here [Re: Kern Dog] #1639457
07/05/14 05:52 PM
07/05/14 05:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That full boogie Dart Hotchkiss is doing will be hard to beat by any of us, but then again, with as much work and $ as it has in it you may as well resurrect a retired NASCAR!
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639458
07/05/14 06:12 PM
07/05/14 06:12 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Congrats on getting a car that is far beyond most on the road, not just old Mopars. Here's a couple of pics from the 07 Speed Fest.
Re: no talk of Tim's Valiant being for sale here [Re: Kern Dog] #1639459
07/05/14 06:20 PM
07/05/14 06:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes.
His new car/build: https://board.moparts.org/ubbthreads/show...e=0#Post8073886
Re: no talk of Tim's Valiant being for sale here [Re: ScottSmith_Harms] #1639460
07/05/14 07:05 PM
07/05/14 07:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The chassis craftmanship is prettier. I'm sure it will be a visual showcase of sorts for Hotchkis.
The cage work and chassis sheet metal is just extensive. I think it's going to have stock suspension pick up points. Or maybe leaf springs moved in. About the only thing in common with the Red Valiant.
The Dart is a Tour De Force. The Red Valiant is a Grassroots Campaign.
Re: no talk of Tim's Valiant being for sale here [Re: autoxcuda] #1639461
07/05/14 08:27 PM
07/05/14 08:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I wouldn't count out the Valiant against that Dart, but I wouldn't bet against the Dart either! Having a stiff strong chassis is paramount to fine tuning the other components of a race car, takes out a lot of variables. The modern Hemi drivetrain, fuel injection, electric steering, etc. will make that Dart easier to drive smoothly, which usually equals speed. At any rate, we'll eventually find out when we get the chance to flog them at the same event.
