Page 3 of 5 1 2 3 4 5
Re: Anyone running 14" brakes rotors? [Re: MuuMuu101] #1638591
01/06/15 11:33 PM
01/06/15 11:33 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Knowing what caliper it uses is a pretty big concern for me because of pad selection.
Re: Anyone running 14" brakes rotors? [Re: bordin34] #1638592
01/07/15 02:19 AM
01/07/15 02:19 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My Stage 4 brake kit uses the same pads as second generation (ie '05) Viper calipers.
Re: Anyone running 14" brakes rotors? [Re: DoctorDiff] #1638593
01/07/15 02:48 AM
01/07/15 02:48 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Good to know!
Re: Anyone running 14" brakes rotors? [Re: DoctorDiff] #1638594
01/07/15 05:20 PM
01/07/15 05:20 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello Cass,
On your site how do we tell stage 1 from stage 2 etc? I did not see a stage 4 kit is why I asked.
Damon
Re: Anyone running 14" brakes rotors? [Re: mopardamo] #1638595
01/07/15 05:59 PM
01/07/15 05:59 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
Re: Anyone running 14" brakes rotors? [Re: shawge] #1638596
01/07/15 10:22 PM
01/07/15 10:22 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Thank You
Re: Anyone running 14" brakes rotors? [Re: OzHemi] #1638597
02/05/15 08:46 PM
02/05/15 08:46 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
Wheels with flatter spokes can make it easier...mine is a little tight but works well. I have good clearance on the outside diameter sort of area.
Or ...
Re: Anyone running 14" brakes rotors? [Re: go-fish] #1638598
02/05/15 11:32 PM
02/05/15 11:32 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
My calipers are 8 piston Brembos, so might be a little larger then those as well? (On 360mm rotors)
I still have decent clearance to the spokes of my wheels...but every combo will be slightly different I would say, depending on wheels with spoke shape, mounting pad height, and rotor height people use.
(Mine are 2 piece, so no bolts along the inside edge eight depending on how close people's calipers may come to that area?)
Re: Anyone running 14" brakes rotors? [Re: OzHemi] #1638599
02/05/15 11:34 PM
02/05/15 11:34 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
So how did the Tostito do running on he beach?
Re: Anyone running 14" brakes rotors? [Re: moparpollack] #1638600
02/05/15 11:48 PM
02/05/15 11:48 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I tried to keep out of the sand as much as possible.
And happy birthday!
Re: Anyone running 14" brakes rotors? [Re: OzHemi] #1638601
02/06/15 12:32 AM
02/06/15 12:32 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Speaking of large brakes...check this out...a buddy in Oz ordered a set of brakes for a ZR1 that he is going to retrofit onto a Torana (like mine). Carbon rotor, HUGE (nearly 15.5") and weighs next to nothing !
Re: Anyone running 14" brakes rotors? [Re: OzHemi] #1638602
02/06/15 04:15 AM
02/06/15 04:15 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Having the billet hats and the carbon disc is probably a 40 lb weight reduction off one end of a car if you replaced steel with those.
Mopar to the bone!!!
Re: Anyone running 14" brakes rotors? [Re: 72Swinger] #1638603
02/06/15 04:20 AM
02/06/15 04:20 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
It would have to think it would be way less than half the weight of mine easily if not more.. (and an inch larger in diameter)
I might toss it on a scale tomorrow for the heck of it.
Still waiting for the other 3 rotors to turn up for him too, be any day now I would imagine.
Re: Anyone running 14" brakes rotors? [Re: AndyF] #1638604
02/06/15 05:50 AM
02/06/15 05:50 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Most everything fits the late B-body knuckle.
I thought most of the Wilwood kits fit small bearing drum knuckles.
Re: Anyone running 14" brakes rotors? [Re: 72Swinger] #1638605
02/07/15 02:35 AM
02/07/15 02:35 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
13.2 pounds for one!
Re: Anyone running 14" brakes rotors? [Re: OzHemi] #1638606
02/07/15 04:45 AM
02/07/15 04:45 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Vs probably close to 50 lbs for a similar 15.5" steel rotor. That's a lot of rotational energy you're saving.
Re: Anyone running 14" brakes rotors? [Re: OzHemi] #1638607
02/07/15 03:17 PM
02/07/15 03:17 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
What does those carbon rotors cost? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone running 14" brakes rotors? [Re: astjp2] #1638608
02/07/15 03:36 PM
02/07/15 03:36 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
They are GM/Brembo replacements for a ZR1, think they are like 2006 and up?
Prices vary a little depending on seller, think like $1300 - 1500 each or so ? (I didn't order them so don't know for sure) just looked around a little online out of curiosity.
I have front and rear rotors and all 4 calipers laying around until I send them to Oz.
Re: Anyone running 14" brakes rotors? [Re: astjp2] #1638609
02/07/15 03:42 PM
02/07/15 03:42 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I would have guessed 2500 per rotor, but at 1500 per, that is a lot cheaper than other offerings at SEMA that were in the 9-11k price range.
of course the term "cheaper" doesn't really apply here.
cool stuff!
Re: Anyone running 14" brakes rotors? [Re: ntstlgl1970] #1638610
02/07/15 03:53 PM
02/07/15 03:53 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Wilwood's 14" carbon ceramics are about $2300 per rotor.
