Re: Anyone running 14" brakes rotors?
[Re: DoctorDiff]
#1638593
01/07/15 02:48 AM
01/07/15 02:48 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
My Stage 4 brake kit uses the same pads as second generation (ie '05) Viper calipers.
Good to know!
[Re: OzHemi]
#1638597
02/05/15 08:46 PM
02/05/15 08:46 PM
Posts: 693 Coronado, CA
go-fish
Coronado, CA
Wheels with flatter spokes can make it easier...mine is a little tight but works well. I have good clearance on the outside diameter sort of area.
Or ...
[Re: go-fish]
#1638598
02/05/15 11:32 PM
02/05/15 11:32 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
My calipers are 8 piston Brembos, so might be a little larger then those as well? (On 360mm rotors) I still have decent clearance to the spokes of my wheels...but every combo will be slightly different I would say, depending on wheels with spoke shape, mounting pad height, and rotor height people use. (Mine are 2 piece, so no bolts along the inside edge eight depending on how close people's calipers may come to that area?)
[Re: OzHemi]
#1638599
02/05/15 11:34 PM
02/05/15 11:34 PM
moparpollack
Lil Herman
Lil Herman
85086
So how did the Tostito do running on he beach?
[Re: 72Swinger]
#1638603
02/06/15 04:20 AM
02/06/15 04:20 AM
OzHemi
Garden Grove, CA
It would have to think it would be way less than half the weight of mine easily if not more.. (and an inch larger in diameter) I might toss it on a scale tomorrow for the heck of it. Still waiting for the other 3 rotors to turn up for him too, be any day now I would imagine.
[Re: AndyF]
#1638604
02/06/15 05:50 AM
02/06/15 05:50 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
Most everything fits the late B-body knuckle.
I thought most of the Wilwood kits fit small bearing drum knuckles.
[Re: 72Swinger]
#1638605
02/07/15 02:35 AM
02/07/15 02:35 AM
OzHemi
Garden Grove, CA
Speaking of large brakes...check this out...a buddy in Oz ordered a set of brakes for a ZR1 that he is going to retrofit onto a Torana (like mine). Carbon rotor, HUGE (nearly 15.5") and weighs next to nothing !
Having the billet hats and the carbon disc is probably a 40 lb weight reduction off one end of a car if you replaced steel with those.
13.2 pounds for one!
[Re: OzHemi]
#1638606
02/07/15 04:45 AM
02/07/15 04:45 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Vs probably close to 50 lbs for a similar 15.5" steel rotor. That's a lot of rotational energy you're saving.
[Re: OzHemi]
#1638607
02/07/15 03:17 PM
02/07/15 03:17 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
What does those carbon rotors cost? Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1638609
02/07/15 03:42 PM
02/07/15 03:42 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
I would have guessed 2500 per rotor, but at 1500 per, that is a lot cheaper than other offerings at SEMA that were in the 9-11k price range.
of course the term "cheaper" doesn't really apply here.
cool stuff!
