Page 2 of 5 1 2 3 4 5
Re: Anyone running 14" brakes rotors? [Re: MuuMuu101] #1638571
06/28/14 02:43 AM
06/28/14 02:43 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Oz and Feets made their own from Mercedes rotors and Calipers. I believe 72Swinger used an AndyF kit or made his own utilizing Viper calipers. From my reading, 18" wheels are a tight fit and may require the outside edge of the rotors to be turned down to bring the calipers in a little.
Yep, 360mm x 36mm Mercedes rotor with 8 piston Brembo calipers..no problem with fitment under my 18" wheels, but they are made for extra caliper clearance on race cars, so plenty of room around the caliper.
And as Feets has mentioned numerious times, they are on the heavy side..but hard to beat for the price I suppose.
Re: Anyone running 14" brakes rotors? [Re: Uhcoog1] #1638572
06/28/14 08:29 AM
06/28/14 08:29 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
15/16" Master Cylinder, manual
rear bias adjuster
Caddy CTS-V pads (~0.3" taller than viper pads)
'Stock' Brembo pads in rear (HP1000), Raybestos ST-47 pads in front
Front:
Spindle- 73+ a body disc
Hub- aluminum, from dr diff
Bracket- steel, from dr diff
Front:
Rear:
Floater 9"
Ruff stuff specialties weld on brake brackets chopped down and re-drilled
1.5"x1.5" aluminum bar stock for adapter
Rear:
Did I read that the diff doctor was not going to make those brackets anymore though?
**Photobucket sucks**
Re: Anyone running 14" brakes rotors? [Re: 70Cuda383] #1638573
06/28/14 10:03 AM
06/28/14 10:03 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
are any of these "factory" rotor applications that you can find at an autoparts store? or is everyone ordering mail order?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Anyone running 14" brakes rotors? [Re: 70Cuda383] #1638574
06/28/14 12:21 PM
06/28/14 12:21 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
rear bias adjuster
Front:
Front:
Rear:
Floater 9"
Rear:
I called a few weeks ago, he isn't interested in doing them at the moment. The last 5 sets took years to sell.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Anyone running 14" brakes rotors? [Re: AndyF] #1638575
06/28/14 05:31 PM
06/28/14 05:31 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
The mounting system is designed to handle different rotor diameters. You just add a spacer to move the caliper up to go from 13 to 14 to 15 inches.
Thanks for the photo and info, that is helpful to know how easy it would be to change rotor sizes.
Re: Anyone running 14" brakes rotors? [Re: 451Mopar] #1638576
07/28/14 04:06 AM
07/28/14 04:06 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I looked into doing the 15" Grand Cherokee rotors and calipers, they are doable on the drum spindles very easily, just wheel fitment was way expensive. Almost 1000 per wheel for the right back spacing. I set up 12" rotors and calipers from a crown vic, cheap to do, easy to get upgraded parts for. Cop cars are abundant and I did my conversion with new rotors for less than $300.00. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone running 14" brakes rotors? [Re: astjp2] #1638577
07/28/14 04:17 AM
07/28/14 04:17 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I used a wilwood hub on B body drum spindle and added a coleman racing 14" rotor then used US Brake caliper with homemade bracket. Stops my 4000lb Charger pretty good and have never had any fade. I get going pretty good at ThunderHill, but I try to stay off my brakes and on the gas pedal.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Anyone running 14" brakes rotors? [Re: HUSTLESTUFF] #1638578
07/30/14 03:57 PM
07/30/14 03:57 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Well this caused me several sleepless nights thinking of how I can make the 15" Grand Cherokee Brembos work on the Charger.....hmmm now to do a little more planning!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone running 14" brakes rotors? [Re: astjp2] #1638579
07/30/14 04:45 PM
07/30/14 04:45 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Is there any particular reason you want such a heavy rotor up front?
Life will by much happier (easier) if you go with a more reasonably sized 13" or even 14" rotor. Wheels and tires will be less expensive and your performance will likely go up.
- Stu Harmon
Re: Anyone running 14" brakes rotors? [Re: feets] #1638580
07/31/14 01:10 AM
07/31/14 01:10 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
cool factor! and the challenge to see if I can make it fit?> I made the crown vic 12" calipers and rotors fit real easy on the drum spindle, this was more of a mental exercise than anything...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone running 14" brakes rotors? [Re: astjp2] #1638581
07/31/14 03:09 AM
07/31/14 03:09 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Aside from having to run large wheels on the front to clear that size a rotor...why not just make up some brackets and go then ?
Re: Anyone running 14" brakes rotors? [Re: OzHemi] #1638582
08/01/14 03:16 AM
08/01/14 03:16 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Rotors are not offset enough, no one makes a wheel for less than 1k each to fit a B body. I might be able to get custom rotors and then use an affordable wheel, but Feets gave me crap about wanting to run cheap wheels...so I am stickin with the 12" for now until I get another 20K rounded up to put the car back together. The mental exercise is fun to see if I can make it work though. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone running 14" brakes rotors? [Re: astjp2] #1638583
08/01/14 05:04 PM
08/01/14 05:04 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I didn't intend to give you crap.
You can make anything work if you have enough money to throw at it.
One reason I used the 2003-2006 S-class rotors was to get the rotor surface back as far as possible. That gave me more caliper to wheel clearance. They get close to the outside of the wheel but the biggest concern is between the back of the spokes and the side of the brake caliper. Multi-pistion calipers are really w-i-d-e.
- Stu Harmon
Re: Anyone running 14" brakes rotors? [Re: feets] #1638584
08/01/14 05:14 PM
08/01/14 05:14 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
really w-i-d-e.
Re: Anyone running 14" brakes rotors? [Re: feets] #1638585
08/01/14 05:22 PM
08/01/14 05:22 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Wheels with flatter spokes can make it easier...mine is a little tight but works well. I have good clearance on the outside diameter sort of area.
Re: Anyone running 14" brakes rotors? [Re: AlexP] #1638586
01/04/15 05:06 AM
01/04/15 05:06 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
rear bias adjuster
Front:
Front:
Rear:
Floater 9"
Rear:
I tried him a few months before that, same story, how many would he need to make it worth his while I would gladly pay upfront...or anyone with the required equipment to replicate it if he has no interest.
Re: Anyone running 14" brakes rotors? [Re: challenger70] #1638587
01/05/15 11:05 PM
01/05/15 11:05 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Is there anything out there that will fit a 73+ B-body spindle?
Re: Anyone running 14" brakes rotors? [Re: bordin34] #1638588
01/06/15 12:34 AM
01/06/15 12:34 AM
AndyF Online content
AndyF  Online Content
Most everything fits the late B-body knuckle.
Re: Anyone running 14" brakes rotors? [Re: AndyF] #1638589
01/06/15 01:42 AM
01/06/15 01:42 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I see dr.diff lists a 13" rotor with a 4 piston caliper for my knuckle. Do you know if that is currently produced and where the caliper is sourced from? I would like to get the pedal feel similar to that of my 944 that has 4 piston brembos on all four corners 300mm rotors and braided lines.
Re: Anyone running 14" brakes rotors? [Re: bordin34] #1638590
01/06/15 01:49 AM
01/06/15 01:49 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I'm in the middle of the install, but I'd say they're generic parts. I know the rotors are Mercedes based. I'm not sure about the calipers.
