Swap 05 hemi for 06 #1638526
06/26/14 01:05 AM
06/26/14 01:05 AM
MN
dodgebro Offline OP
dodgebro  Offline OP
MN
Blew up the 5.7 hemi in my 06 300c. Sucked water into intake and it threw a rod. Have a chance to buy a 05 hemi from a Charger. What issues with this swap?
Was told this wouldn't work, too many differences. Anyone know what would change?
Re: Swap 05 hemi for 06 [Re: dodgebro] #1638527
06/26/14 07:10 PM
06/26/14 07:10 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Not sure what year they changed the reluctor wheel tooth count but that would be the most difficult to overcome.. The sensors have changed the plugs over the years so I do not know if they are different but if the are just use your old sensors on the replacement engine same could be true about the intake and injectors..
Re: Swap 05 hemi for 06 [Re: rumblebee4232] #1638528
06/27/14 12:53 AM
06/27/14 12:53 AM
MN
dodgebro Offline OP
dodgebro  Offline OP
MN
Anyone know if I can just swap the tone ring or reluctor?
Re: Swap 05 hemi for 06 [Re: dodgebro] #1638529
06/27/14 01:33 AM
06/27/14 01:33 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You will be ok with the tone ring and reluctors. May have to change valve covers, wires and coil packs though.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Swap 05 hemi for 06 [Re: 71yelladustr] #1638530
06/27/14 09:30 PM
06/27/14 09:30 PM
Wichita Kansas
6PacCuda Offline
6PacCuda  Offline
Wichita Kansas
Check to see if it has the MDS. If it has the cylinder shut down it may not work. I think the ignition system may be different also. I think there is a difference with the coils.
