S.B. Edelbrock Heads & 1.6 Rocker Arms ? #1638409
06/25/14 09:35 PM
06/25/14 09:35 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
Debating Changing From 1.5 To 1.6 Rocker Arms On A 340 That Has Out Of The Box Edelbrock Heads. I Have Plenty Of Valve To Piston Clearence, But Do Need To Know If The Edelbrock Heads Push Rod Holes Are Good To Go With The Added Angle Of The 1.6'S ? Thank You.
Re: S.B. Edelbrock Heads & 1.6 Rocker Arms ? [Re: titan] #1638410
06/25/14 09:49 PM
06/25/14 09:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pull a few valve spring and put light springs on them
to test it... I would just do the intakes myself..
I have never had any improvement on the exhaust...
but when you have the checker springs on you can roll
the engine over a bit at a time then push down
on the valve side a little and see how far you can
move the push rod towards the shaft to check clearance
Re: S.B. Edelbrock Heads & 1.6 Rocker Arms ? [Re: MR_P_BODY] #1638411
06/25/14 10:18 PM
06/25/14 10:18 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
I've got T&D 1.6 on mine no clearance issues with the push rods, running Smith bros. push rods
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: S.B. Edelbrock Heads & 1.6 Rocker Arms ? [Re: Stroker Scamp] #1638412
06/26/14 05:16 AM
06/26/14 05:16 AM
illinois
moparpiff Offline
moparpiff  Offline
illinois
Out of curiosity what part number i are your heads. The set I have I my pushrods almost rub on the intake side of the pushrod hole with 1.5 rocker.
Re: S.B. Edelbrock Heads & 1.6 Rocker Arms ? [Re: moparpiff] #1638413
06/26/14 10:24 AM
06/26/14 10:24 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't recall what part number my heads are but they are the non magnum head. I am running Erson 1.6 rockers with a total lift of about .650 with no trouble.
68 Barracuda Formula S 340
Re: S.B. Edelbrock Heads & 1.6 Rocker Arms ? [Re: moparpiff] #1638414
06/26/14 10:51 AM
06/26/14 10:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You would gain clearance running the 1.6 rockers
since they move the PR in closer to the shaft
Re: S.B. Edelbrock Heads & 1.6 Rocker Arms ? [Re: MR_P_BODY] #1638415
06/26/14 08:23 PM
06/26/14 08:23 PM
illinois
moparpiff Offline
moparpiff  Offline
illinois
Thanks Mr. Pbody. I have run both 1.6 and 1.5 rockers on these heads and the push rod almost rubs with both of them. My heads are 60179. I am thinking the shaft mounts are out of location or machined out of location. The rockers I have used are crane golds for the 1.6 and stock adjustable rockers for the 1.5s. I am planning on having them looked at this winter before I start the next build with these heads and figuring out why.
Re: S.B. Edelbrock Heads & 1.6 Rocker Arms ? [Re: moparpiff] #1638416
06/26/14 10:20 PM
06/26/14 10:20 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
I Went Ahead And Installed The 1.6's Today & They Have Plenty Of Clearence.
Re: S.B. Edelbrock Heads & 1.6 Rocker Arms ? [Re: moparpiff] #1638417
06/26/14 10:23 PM
06/26/14 10:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It's very unlikely anything is wrong with your valve train stuff. It is what it is, grind away or use a good dinky pushrod. That is pretty much the options.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
