Mopar E-Body Seat Track Dissemble? #1638346
06/25/14 06:09 PM
06/25/14 06:09 PM
Georgia
Steve Bryant Offline OP
Georgia
Working to re-cover my Cuda seats and I have some slightly rusty but functional tracks I was considering taking apart to blast, paint and grease. The very few sources I have found suggest that the parts are hard to find and I am wondering if I am better off stripping the outer surface rust and then painting and greasing. Plus, I can't figure out how to separate the tracks anyway.
First question is how do I disassemble the tracks? Do I straighten the little bend shown in the photo to the whole track will slide out?
Second question is should I do this? The only articles I see are pretty candid about the scarcity of the track parts and if I lose a bearing or slide I could have to buy a new entire track .
What do you think?
Re: Mopar E-Body Seat Track Dissemble? [Re: Steve Bryant] #1638347
06/25/14 07:53 PM
06/25/14 07:53 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Bend that part down and the other end and it will come appart.Watch for the ball bearings,sometimes they will fall out.
Re: Mopar E-Body Seat Track Dissemble? [Re: 5carguy] #1638348
06/25/14 08:08 PM
06/25/14 08:08 PM
Georgia
Georgia
5carguy, thanks! I wanted to make sure before I start breaking things!
Re: Mopar E-Body Seat Track Dissemble? [Re: Steve Bryant] #1638349
06/25/14 08:29 PM
06/25/14 08:29 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Just bend them back when your finished with the resto.Wait until you finish them with cleaning and new grease.You will not believe it.
Re: Mopar E-Body Seat Track Dissemble? [Re: 5carguy] #1638350
06/25/14 09:07 PM
06/25/14 09:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
On my b-body ones I cleaned all the grease out of them first (hot tank) then blasted them then soaked them in a rust converter to get the stuff in the poors. Then I primed and painted them and lubed them. It seemed pointless to me to take them all apart since there should be minimal damage (rust) in the tracks due to the grease.
Re: Mopar E-Body Seat Track Dissemble? [Re: Stanton] #1638351
06/25/14 10:43 PM
06/25/14 10:43 PM
Georgia
Georgia
Mine is soaking overnight and tomorrow I will hit it with a wire wheel and then bead blasting but I wanted to know if these look bent to you?
Actually, I have a couple of questions..
1) Should the silver ball be "locked" tight between those two supports?
2) Does the spring steel "guide" for the rollers and balls look bent to you?
With the guide inside the rail, the large steel cylinder rolls but at an angle against the rail and not parallel like I would have thought. My suspicion is the "guide" is bent from someone slamming the seat but I wanted to check with smarter people than myself to see what they think.
Re: Mopar E-Body Seat Track Dissemble? [Re: Steve Bryant] #1638352
06/26/14 12:23 AM
06/26/14 12:23 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yeah, that looks bent to me.
