UPDATE- High oil pressure after tubing lifter gallery #1638178
06/25/14 02:03 AM
06/25/14 02:03 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
So some of you might rememeber my lengthy thread from not too long ago about my very low oil pressure issue. I ended up tubing my block as per the mopar performance manual, got it all cleaned up and assembled and went to go prime the engine on the stand today. The only changes I made were- tubing the block, removing the restrictors I installed feeding the rocker shafts in the Indy heads, and removing the high pressure spring from my high volume pump and re-installing the standard pressure spring.
Using a quite weak air powered drill, pressure pegged the 100 psi on the gauge instantly, with little to no drop at all. Oil is getting to the heads and draining back sufficiently. I am thinking that possibly now with the lifter gallery tubed the oil pressure is much higher since there is less area for oil to bleed out/fill in.
Has anybody had this issue before? I am certain the cup plug was installed the correct way on the oil pump. At this point I am going to try installing the standard volume pump, but just wondering if this is normal after tubing the block and if it could be something else I have looked over?
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638179
06/25/14 02:18 AM
06/25/14 02:18 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Sounds like pressure release is stuck in the pump. Just takes smallest speck of dirt or scratch to stick them.
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638180
06/25/14 08:41 AM
06/25/14 08:41 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My 572 had oil psi issues last year. Running a B/B the I have the luxury of an adjustable bypass spring. My engine push rod oils. The oil feed holes in my lifters were epoxied. Reducing the 2 feed holes from .110" to one feed at .040". It was necessary to turn the adjuster back .200". It runs 5w/30 oil, .003" bearing clearance and shows over 100psi at start-up. However after warmed up (oil temp over 100) it holds 35-40 at idle and 60 through the traps. Don't condemn the pump until you test with warm oil.
Doug
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638181
06/25/14 10:47 AM
06/25/14 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Put the standard pump on and see what you get...
so all of the massive leak was in the lifters
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: MR_P_BODY] #1638182
06/25/14 11:29 AM
06/25/14 11:29 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
If the bypass is being stuck open, is that something I can check for when removing the pump? How can I see if that was the problem- pull the cup for the bypass spring out and the spring and take a looksie?
Other then running the engine on an engine stand (And it is not totally buttoned up yet), how would I be able to see what the hot oil does? I have had 70 psi cold before in other motors, but never 100. That just seems way too high cold, even with 10w30wt oil like I used to prime it.
And yes, it did end up being the lifters that were causing my pressure loss. I still kept the intake off when I was priming just to watch drainback from the heads and to see if the mod worked in blocking the oil from the lifters. The cam bearings at #2 and #4 are draining losing oil, but it must be normal and I just did not know what to expect when watching oil coming from the full groove cam journals since the oil pressure is now quite high.
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638183
06/25/14 11:38 AM
06/25/14 11:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
IF its stuck its stuck CLOSED.. otherwise you would
be in the 70# range(the by-pass would open around 70#)
and dump the excess oil back... yes the 2 and 4 will
have oil dumping from them but its a matter of how
much and thats really hard to say whats normal if you
cant run that through a flow meter.. but like you I
still feel the lifters are/were the major leak and
on my engine with bushed bores and the .062 hole in
each one is still a major leak with the EDM hole on
the lifters and PR oiling on mine and the loss around
the lifters
EDIT
what weight oil are you running and you could put
a few qts of 5 weight in to simulate hot oil(just
enough to prime the system)
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: MR_P_BODY] #1638184
06/25/14 12:05 PM
06/25/14 12:05 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
The oil pump runs at half engine speed and most drills usually turns faster than that, So what you are seeing may not be what it will be when it is running
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: SB412DUSTER] #1638185
06/25/14 12:34 PM
06/25/14 12:34 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Glad things are looking better Matt. My thought on this is IF you are sure you are going to run a roller cam why wouldn't you want to do this procedure? Its not that hard to do and its controlling where you want the oil not where it wants to go. I did it on the 360 block that I am running now and using a dinky 550 lift solid cam. Its going on its third season with a standard oil pump and 10-30 Brad Penn oil. With the tubed galley you are also protected should a lifter ever pop out of the lifter bore and trust me I've seen it happen.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638186
06/25/14 01:27 PM
06/25/14 01:27 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Pressure is a restriction to flow , so it only makes sense that once you fixed that massive oil leak that is the mail galley running thru the lifter bores that your pressure shot up.
Did you put holes in the tube to get some oil around the lifters ?
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638187
06/25/14 01:57 PM
06/25/14 01:57 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
STandard volume pump first.
RIP Monte Smith
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: CompWedgeEngines] #1638188
06/25/14 05:28 PM
06/25/14 05:28 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Not unusual for melling hv pumps to give too much pressure.
Think ive had 2 or more of them.
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: sshemi] #1638189
06/25/14 05:39 PM
06/25/14 05:39 PM
PA.
"Little"John
"Little"John
PA.
Pretty sure I have a like new one (high volume) still laying under my work bench that was putting out over 130 pounds of pressure during a 1/4 mile pass. Thank God I didn't have a Fram oil filter on my Duster.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: pittsburghracer] #1638190
06/25/14 06:13 PM
06/25/14 06:13 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I know the pump turns at half engine speed, but the gauge pegs 100psi almost immediately.
I never did this mod before I put the engine together because to be honest, I never really even knew about it...I thought with "drop in" roller lifters there was no need to modify a thing.
The Melling HV pump that I put in is not a brand new untested pump, it ran all last season in this motor. So that is why I am thinking maybe the HV pump is going to now create too much pressure (yes, I did drill the holes up from the mains to the tubed gallery). I guess I can try the standard volume pump that I already have and see what happens. Hopefully everything will be ok and I can drop the engine back in the car this weekend or shortly after.
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638191
06/25/14 07:39 PM
06/25/14 07:39 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 408 had quiet a bit more oil pressure when I primed it than it does running.
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: justinp61] #1638192
06/26/14 12:26 AM
06/26/14 12:26 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Heat the oil on your stove, check the temp get it to about 120 or 150. Dump it in the valley then try it
....BAD A$$ STREET CAR.....
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638193
06/26/14 07:38 AM
06/26/14 07:38 AM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
your reading is inaccurate if you are not turn the crankshaft.
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: CRIKEY] #1638194
06/27/14 12:40 AM
06/27/14 12:40 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I always do turn the crank when I am priming the motor...made no difference.
Anyways, I installed the standard volume pump and standard pressure spring back in, no other changes...same oil, same temperature, I got 70-75psi on the gauge. Bolted the intake on, and this thing is finally ready to go back in the car.
I am keeping my fingers crossed that this is the last stupid roadblock I encounter this season. If I tear into the engine to change anything over the winter other then broken parts, someone please come and knock me on my ass! LOL...I am done working on issues and just want to race and dial this combo in
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638195
06/27/14 12:42 AM
06/27/14 12:42 AM
Syracuse,NY
Syracuse,NY
Yep..
RIP Monte Smith
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: CompWedgeEngines] #1638196
06/27/14 12:44 AM
06/27/14 12:44 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Yep..
Thankfully it was an easy fix and I did it on the stand instead of fighting with it all in the car.
Re: UPDATE- High oil pressure after tubing lifter gallery [Re: mshred] #1638197
06/27/14 09:29 AM
06/27/14 09:29 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I have always tubed all my small blocks with solids or solid rollers. The other added benefit is that when you go to check bearings when freshening the motor you are going to be pleasantly surprised on how good of condition they will be in after a lot of runs or street miles-Randy
