BRAKE RELEASE ISSUES / 78 MAGNUM
#1638152
06/25/14 12:29 AM
06/25/14 12:29 AM
Posts: 10,646 S.E.Ohio
Magnumguy
S.E.Ohio
Replaced both front calipers (rebuilt) and hoses on my 78 Magnum. It seems like they're not releasing as the should, as when i raise either one they're hard to turn, even worse w/the wheel/tire off.
Any clues? Pads are correct, dead-on matches to the ones removed. Also had an awful time getting them bled as well.
Re: BRAKE RELEASE ISSUES / 78 MAGNUM
[Re: Magnumguy]
#1638153
06/25/14 12:51 AM
06/25/14 12:51 AM
RapidRobert
I'm assuming the wheel bearing adjustment is OK. Cranck a bleeder & see if it is a PSI problem. I had that on one corner & a $15 rebuild caliper took care of it. Before it was too hard to turn it & with another caliper it was much easier to bearhug/turn the wheel which as you know is normal EDIT provide more info on what was going on with the bleeding
[Re: 340SHORTY]
#1638156
06/25/14 10:36 AM
06/25/14 10:36 AM
Magnumguy
S.E.Ohio
Proportioning valve needs reset..
How is that done?
is the booster releasing all the way ??
As far as I can tell it is.
[Re: Magnumguy]
#1638157
06/25/14 10:45 AM
06/25/14 10:45 AM
RapidRobert
didn't realize it was PB. crack a bleeder & if that frees it then close the bleeder & pump it up & undo the MC to booster bolts & pull the MC forward a bit & see if that frees it. If so take the bolts the rest of the way off & pull the MC forward so you can get at the rounded pushrod threaded nub & shorten it till you have a slight bit of clearance between the round nub and the bottom of the piston recess "thimble" in the back of the MC
