fire coming from headers #1637996
06/24/14 07:23 PM
06/24/14 07:23 PM
rogersville,mo.
dart340x2 Offline OP
rogersville,mo.
I have been told that i have flames coming from the headers. What could be causing this problem?
Re: fire coming from headers [Re: dart340x2] #1637997
06/24/14 07:25 PM
06/24/14 07:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your timing
Re: fire coming from headers [Re: MR_P_BODY] #1637998
06/24/14 07:38 PM
06/24/14 07:38 PM
rogersville,mo.
rogersville,mo.
It is at 34
Re: fire coming from headers [Re: dart340x2] #1637999
06/24/14 07:46 PM
06/24/14 07:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I guess we should start at the beginning.. whats the
engine and combo... and have you done a compression
check to see if you have a valve issue(or a leak down)
and is it on decell they see flames
Re: fire coming from headers [Re: MR_P_BODY] #1638000
06/24/14 07:51 PM
06/24/14 07:51 PM
rogersville,mo.
rogersville,mo.
The engine is a 416 with brodix b1ba heads and a 600 lift roller cam. Compression is 10.5 to 1. I have not done a compression check. and it is on acceleration it seems
Re: fire coming from headers [Re: dart340x2] #1638001
06/24/14 08:29 PM
06/24/14 08:29 PM
johnmilner Offline
johnmilner  Offline
running a little rich
Re: fire coming from headers [Re: johnmilner] #1638002
06/24/14 08:45 PM
06/24/14 08:45 PM
rogersville,mo.
rogersville,mo.
I am running methanol. I had 160 jets all around I now have 152's.
Re: fire coming from headers [Re: dart340x2] #1638003
06/24/14 08:48 PM
06/24/14 08:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How big is the carb and whats the jetting.. sounds
like your putting raw fuel into the pipes... also
are you running a PV and the biggest thing is what
are the plugs telling you.. sounds like they should
be dark if you pull one or two at the end of the track
Re: fire coming from headers [Re: MR_P_BODY] #1638004
06/24/14 08:54 PM
06/24/14 08:54 PM
rogersville,mo.
rogersville,mo.
It is an 850 quick fuel.
Re: fire coming from headers [Re: dart340x2] #1638005
06/24/14 09:00 PM
06/24/14 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you tried leaning it down to find the best MPH
Re: fire coming from headers [Re: MR_P_BODY] #1638006
06/24/14 09:22 PM
06/24/14 09:22 PM
rogersville,mo.
rogersville,mo.
Yes I had 160 jets and I have 152 in it now.
Re: fire coming from headers [Re: dart340x2] #1638007
06/24/14 09:25 PM
06/24/14 09:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So is the mph picking up and are the flames less
Re: fire coming from headers [Re: MR_P_BODY] #1638008
06/24/14 09:38 PM
06/24/14 09:38 PM
rogersville,mo.
rogersville,mo.
I have not got to make a pass yet.
