Page 2 of 3 1 2 3
Re: Spark plug images [Re: Quicktree] #1637877
06/25/14 02:25 PM
06/25/14 02:25 PM
canada
jp15 Offline
jp15  Offline
canada
same material I've went by for years Quicktree .
Re: Spark plug images [Re: Quicktree] #1637878
06/25/14 02:54 PM
06/25/14 02:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
really, what is the ground strap telling you?
I don't honestly know, that's why I posted the photos. I'll have to order a set of 8s.
go watch the video i posted and come back and report, the message is clear.
Not sure about a clear message but I dig the jazzy groove........
Re: Spark plug images [Re: Thumperdart] #1637879
06/25/14 06:59 PM
06/25/14 06:59 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
wrong heat range, WAY too lean, WAY too much timing...initial and total and maybe even too much gap......
Re: Spark plug images [Re: bwhackd34] #1637880
06/26/14 12:19 AM
06/26/14 12:19 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I made some changes to the carb this week and took it for a spin today. I went from 76/88 jets and 31/71 air bleeds to 78/88 jets and 29/71 air bleeds. Idle afr was 14.3-14.8, 3000 rpm cruise was 12.3-12.5 and wot was 12.4-12.6. The plugs have color now, I'd guess from being rich at cruise where it spent most time at. I'll order some ngk 8s, for now I'll put in a set of Autolite AR3934 after I work on the cruise.
2,4,6 & 8.
Re: Spark plug images [Re: justinp61] #1637881
06/26/14 02:17 AM
06/26/14 02:17 AM
Az
Crizila Offline
Crizila  Offline
Az
2,4,6 & 8.
They look better. I am running R5671A-8 NGK's and thinking about switching to AR3934's. They are a direct cross.
Fastest 300
Re: Spark plug images [Re: justinp61] #1637882
06/26/14 02:31 AM
06/26/14 02:31 AM
2,4,6 & 8.
If you didn't put new plugs in before doing the carb. tuning you should. The two plugs on the left are fatter than needed, the one next to the last one on the right side and especially the last one on the right are close to what I like to see When it comes to tuning, lean is mean and cold sprak plugs that don't foul at part throttle are just right
Re: Spark plug images [Re: Crizila] #1637883
06/26/14 03:31 AM
06/26/14 03:31 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
2,4,6 & 8.
You may need 8`s w/your combo but not sure Justin does and now the heat/timing band looks better but I could be wrong.............
Re: Spark plug images [Re: Thumperdart] #1637884
06/26/14 07:26 AM
06/26/14 07:26 AM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
look a little better...still too much timing and wrong heat range....
Re: Spark plug images [Re: bwhackd34] #1637885
06/26/14 08:16 AM
06/26/14 08:16 AM
W. Kentucky
W. Kentucky
The timing is 21 initial and 34 total. I've got to work on the cruise then I'll repost some photos.
Re: Spark plug images [Re: bwhackd34] #1637886
06/26/14 02:09 PM
06/26/14 02:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I guess different guys read em differently...........years ago the heat range was measured(by some)as the amount of threads colored going up the plug as seen from the ground strap ie; 2-3 threads was considered good 1 too cold 5 too hot. I know when I went to a colder plug the band on the ground strap mover farther out towards the end.
Re: Spark plug images [Re: Thumperdart] #1637887
06/26/14 06:26 PM
06/26/14 06:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
go watch the video i posted and learn you some of this new technology
Re: Spark plug images [Re: Quicktree] #1637888
06/26/14 06:37 PM
06/26/14 06:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want Tony I can show you other sites that
say the ground strap is timing.. and I can move the
blue line with the timing... that changes the heat
in the cyl also... let me know if you want me to post it
Re: Spark plug images [Re: MR_P_BODY] #1637889
06/26/14 06:44 PM
06/26/14 06:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i have seen that, who is the author? thats what you want to find out? how can timing make the band on the ground strap move?
Re: Spark plug images [Re: Quicktree] #1637890
06/26/14 07:15 PM
06/26/14 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This guys have a bit of knowledge
http://www.4secondsflat.com/Spark_plug_reading.html
Re: Spark plug images [Re: MR_P_BODY] #1637891
06/26/14 07:25 PM
06/26/14 07:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what ever you want to believe i guess, i can see timing changing exhaust gas temp but don't see how it can change the ground strap. the only thing that can change that is the plug heat range imo.
Re: Spark plug images [Re: Quicktree] #1637892
06/26/14 07:30 PM
06/26/14 07:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I guess you can think the way you want... I'll stay
with what I and many others think also... so we will
call it equal... hows that
Re: Spark plug images [Re: MR_P_BODY] #1637893
06/26/14 07:43 PM
06/26/14 07:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
fine with me I still would like you to explain how it can single out the ground strap and change it.
Re: Spark plug images [Re: Quicktree] #1637894
06/26/14 07:58 PM
06/26/14 07:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Simple... start the burn earlier and the temp in
the cyl goes up... if its later it cooler and burns
more in the pipes... I have backed the timing down
on my junk and seen the color move closer to the tip
of the radius on the strap... this is fact not just a
opinion
Re: Spark plug images [Re: MR_P_BODY] #1637895
06/26/14 08:17 PM
06/26/14 08:17 PM
Az
Crizila Offline
Crizila  Offline
Az
opinion
but don't loose sight of the fact that we are not adjusting timing or A/F to make the plugs look happy. Gotta make adjustments in those areas for best HP or at the track, best MPH. Then correct plug choice so they are happy and live for a while - which I can't seem to accomplish.
Fastest 300
Re: Spark plug images [Re: Crizila] #1637896
06/26/14 08:44 PM
06/26/14 08:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
opinion
I know your playing with a boosted engine so on yours
are the plugs fouling out or burning up
Page 2 of 3 1 2 3
