Holley reman thermoquad #163732
12/07/08 11:55 AM
12/07/08 11:55 AM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Has anyone ever used a reman thermoquad from Holley ?
Re: Holley reman thermoquad [Re: AdamR] #163733
12/07/08 12:27 PM
12/07/08 12:27 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Yup. I have one on my duster.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Holley reman thermoquad [Re: CJK440] #163734
12/07/08 12:28 PM
12/07/08 12:28 PM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Any problems with it ? would you buy another or go a different route next time ?
Re: Holley reman thermoquad [Re: AdamR] #163735
12/07/08 12:31 PM
12/07/08 12:31 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
No probs. I'd do it again. It was a nice piece, got it from Summit.
I've bought a bunch of TQ's for parts and usually some screw is frozen or its corroded pretty bad. For what the reman cost it wasn't worth rebuilding one. Came with brass floats and the bowl was resurfaced too.
For my application it did need the seats replaced with larger ones, car was cutting out on the big end.
Re: Holley reman thermoquad [Re: CJK440] #163736
12/07/08 12:33 PM
12/07/08 12:33 PM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Cool, Thanks Chris !
Re: Holley reman thermoquad [Re: CJK440] #163737
12/07/08 02:23 PM
12/07/08 02:23 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I bought one years ago and it had mismatched rods in it. The throttle shaft was loose on the replacement for that one.
I bought a different brand, maybe a Tomco for the same money that didn't require a core deposit.
Now I will just rebuild whatever I want. I collect them.
Where did you find the bigger seats? I didn't know they were available.
I have a strip kit I bought years ago. Never have had an engine that needed the bigger stuff.....yet!!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Holley reman thermoquad [Re: Rug_Trucker] #163738
12/07/08 02:44 PM
12/07/08 02:44 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Adam,
In the name of doing good business I won't knock Holley in public, and I don't know what your goals are (performance/restoration/etc.). I only do stock rebuilds to factory specs. If you desire brass or plastic floats, no problem, I offer you the choice. As far as performance goes, I have a stone stock 71 TQ on my own 426 cube small block, I chose it because it performed the best on the dyno in a direct comparison against some popular modified versions, they are pretty darn good carbs in stock form!
I can make these promises:
It will look original, run like new, and be unconditionally gauranteed for as long as you own it. EVERY aspect of my carbs are rebuilt or refreshed, no skipped steps or parts. All are test run on a running engine, rebushed throttle shafts bores, plating done in the correct colors (Holley does all in only one color BTW) and a proper factory appearing finish on the carb body (unlike most others that just media blast them). You will find no spray painted parts on any carb I offer! 3 week turn around time on average. I can supply some cores if you need one, just let me know the application.
If you have any questions give me a call, advice is free!
Re: Holley reman thermoquad [Re: ScottSmith_Harms] #163739
12/07/08 03:29 PM
12/07/08 03:29 PM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Scott, Just looking at my options really. The car will be a stock appearing driver with a few upgrades. My plans were to make it FAST legal but Im not sure that will happen.
Re: Holley reman thermoquad [Re: AdamR] #163740
12/07/08 03:35 PM
12/07/08 03:35 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well since I'm currently building a FAST legal 340 car myself I can help you on that topic as well. Options are good, there are many choices in carb rebuilders, check them all out then drop me a line, I'll always give you the straight scoop.
509-922-9115
Re: Holley reman thermoquad [Re: ScottSmith_Harms] #163741
12/07/08 04:34 PM
12/07/08 04:34 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Scott is lieing..........box those plastic pieces of junk up and send them to me. I will see that they are properly and safely disposed of.
Re: Holley reman thermoquad [Re: Rug_Trucker] #163742
12/08/08 12:22 PM
12/08/08 12:22 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
It definately is not a concours carb. It's a basic reman just like you would get if you went to the parts store. I was neck deep in aquiring parts and didn't have a good baseline TQ to fire the car up with. Price was right, I took a chance knowing I can send it right back to summit if it was garbage but I guess I got lucky.
I got the bigger seats from Demonsizzler.
Re: Holley reman thermoquad [Re: ScottSmith_Harms] #163743
12/08/08 01:26 PM
12/08/08 01:26 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
nice carb Scott
Re: Holley reman thermoquad [Re: Dakota_Don] #163744
12/08/08 01:39 PM
12/08/08 01:39 PM
I never knew Holley offered a reman TQ.....that's another source to remember.
I have a buddy that's trying to rebuild one I've been running for years. The throttle shafts have some play....not terrible, he says. It's biggest problem is the drip drip drip from the wells.
I am so sick of trying to mate a Holley or a Carterbrock up to a kickdown linkage I could scream. (and yes, I have all their little adapter doodads)
I set a TQ up there and everything just falls into place. My 360 ran better with the old TQ than the new Holley.....it's just a bear to start when hot because of the well leaks. Buddy says this is an easy fix and that he may even have a better thottle plate for it.
I'm all for factory parts. I can't wait to hit the track next summer with a fresh TQ and prove they didn't deserve the "Thermo-bog" nickname.
Sid
Re: Holley reman thermoquad #163745
12/08/08 04:08 PM
12/08/08 04:08 PM
scratchnfotraction Offline
I like the Q-jet myself
with stock linkage or on a speed
run what ya brung
that thermobog looks SWEET!,what do they go for scott?
and what intake is that sittin on?
Re: Holley reman thermoquad [Re: scratchnfotraction] #163746
12/08/08 04:53 PM
12/08/08 04:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No problem, I restore those as well
I don't sell carbs I just restore them, but I can usually find cores if you don't have one.
A bone stock cast iron 1971 340 Thermoquad intake
Re: Holley reman thermoquad [Re: ScottSmith_Harms] #163747
12/08/08 05:40 PM
12/08/08 05:40 PM
When using the TQ....should the fuel pressure be at 7psi like a Holley or do they like a different setting?
Sid
Re: Holley reman thermoquad #163748
12/08/08 11:56 PM
12/08/08 11:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Sid
Same for all of them but I actually I don't reccomend fuel pressure being over 6lbs, 7 being the upper most limit.
Re: Holley reman thermoquad [Re: ScottSmith_Harms] #163749
12/09/08 01:14 AM
12/09/08 01:14 AM
5thAve Offline
5thAve  Offline
I bought a few Holley rebuilt carberators. One never ran right. I brought it back to exchange it and the 2nd one they got for me looked like it was put together with whatever they could find on the floor. Every screw that holds it together was different, some of the ports looked like they were home made, some of them were loose, one of them was even bent shut. I told them to order another one because I wasnt taking it. That one was OK. I have another one that worked almost perfectly without having to do anything with it. None of them were thermoquads tho. I dont think Id get one if it didnt come with warrenty or it wasnt returnable.
