SB Water Pump Brand?
#1637290
06/23/14 08:43 AM
06/23/14 08:43 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I might have to replace the 1 year old NAPA water pump on my 340 and I don't want to have to do it again in another year from now. What brands/part numbers are you running that actually last? Do you run a standard or a high volume unit? http://www.summitracing.com/parts/mil-16250/overview/make/dodge This is one that I found for reference. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: SB Water Pump Brand?
[Re: YO7_A66]
#1637292
06/23/14 10:04 AM
06/23/14 10:04 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Never had an issue using the stock HD version on my small blocks.
[Re: YO7_A66]
#1637293
06/23/14 10:43 AM
06/23/14 10:43 AM
RapidRobert
It was leaking out the weep hole? I've had extremely good luck with water pumps & I'd say the chances of you haveing this happen again are pretty slim. I'd suggest an 8 blader rebuilt one from your parts house & you could weld on an anticav plate. I cut a round piece out of the side of a junk washing machine sitting in the yard with a saber saw with an OD slightly less than the OD of the vane tips cuz you weld it at the vane tips then had my welder tack it on & drill a hole in the center to weld it there where the shaft is also. First mockup & need .040" or more clearance but no less than that (.040" is perfect) to the timing cover "flat" keeping in mind your gasket thickness. Easy to do & greatly increases pump efficiencey & lets you run a higher pump pulley ratio for more flow/better cooling without cavitation. Short answer: buy another one anywhere & toss it on there as is & you will be fine
[Re: RapidRobert]
#1637294
06/23/14 11:37 AM
06/23/14 11:37 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
RR i agree one from a parts store is just as good as the hi buck ones.Its all Ive ever used on any SB.Some time you can get a new not reman for not much more $$$.When I did the pump on my 3.3 it was new Advanced.It was a factory Mopar part in their box new.Rocky
Chrysler Firepower
[Re: autoxcuda]
#1637296
06/23/14 02:32 PM
06/23/14 02:32 PM
therocks
Niles , Ohio
There are millions of parts store ones running around.Back in the day do you think MA wasted time and $$$$ adjusting them.Then they were daily drivers and went hundreds of thousands of miles.But its your $$$$ so pay and take tour choice.I run an aluminum pump and body on my BB.But it was cheap and saved weight.Rocky
Chrysler Firepower
[Re: dogdays]
#1637299
06/23/14 04:47 PM
06/23/14 04:47 PM
YO7_A66
Indiana
Thanks everyone for the replies. I should have time later on in the week to determine if the existing pump is an issue or not. I just wanted to start getting some opinions just in case it needs to come out.
