For those that might be interested I got some gaskets made for a early 5.7 truck front cover water pump area to motor plate made.
I wanted a gasket to seal my AEI motor plate, and thought others might want some too.
Liberty gasket digitized the water pump area and cut gaskets with their CNC knife. I thought they look good and should work well.
I paid to have the set up/digitizing done so now it's just ordering gaskets. They cut me some from MP-15(pink stuff) and D7201 harder gray material in .047 and .031 thick.
If you want some talk to Mark at Liberty Gaskets 949-581-8300. I don't know if he has put a part # on them at this time. You might just ask about the Hemi water pump gaskets he cut for Rod McGregor.
Please do not waste his time, they normally make truck and aircraft gaskets. I plan on using them in the future for other custom gaskets.
Also I would like to say thanks to Greg "Superformance" for his input on a few gasket questions.
Hopefully this will be useful to others doing the same setup. Rod
![](http://i1122.photobucket.com/albums/l529/sparky5r/DSCN1019.jpg)
