Re: brake upgrade questions
[Re: dezduster]
#1636650
06/22/14 04:07 PM
06/22/14 04:07 PM
Posts: 1,581 Friendly, WV
wedgeheaded
Friendly, WV
The propotioning valve is not affected by the power booster. What was changed is the pedal ratio/ motion ratio. Without any change to that ratio/ with what you have and a booster your brakes MAY be very light, too easily locked.
OK. So what do I do?
[Re: wedgeheaded]
#1636651
06/22/14 04:59 PM
06/22/14 04:59 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Get a brake pedal from a power brake equipped truck.
I am truckless..
[Re: wedgeheaded]
#1636653
07/01/14 12:50 AM
07/01/14 12:50 AM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
There are a couple different diameters (to clear 440s) and somewhere along the way, Mopar changed the number of bolts that hold the master to the booster. As a unit, I suspect they will bolt up from 73 through 93. If your junk yard buying, its best to pull everything out of the same truck, booster, master, brake pedal, & linkage. I would get the two brake line fittings for the master as well, some are different. Then as long as you know what year the donner truck was, you can get replacement parts for it, whenever you might need them. Gene
