No left brake light? need help. #1636527
06/21/14 10:12 PM
06/21/14 10:12 PM
illinois
bigblk66_coronet Offline OP
illinois
Hey guys i have a 66 Coronet 500 that i have put all brand new wiring in from front to back 10 years ago.All of a sudden i have no driver side brake light. Changed the bulb and nothing! WTH? Any ideas? Is there something im missing?
.Thanks Joe
Re: No left brake light? need help. [Re: bigblk66_coronet] #1636528
06/21/14 10:21 PM
06/21/14 10:21 PM
SE PA
Yellow Fever Offline
SE PA
Double check the grounds. Test the socket with brake on. Does it light with the turn signal?
Re: No left brake light? need help. [Re: Yellow Fever] #1636529
06/21/14 10:33 PM
06/21/14 10:33 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try lifting the turn signal stalk a bit.My 69 Bee did the same thing.When I lifted the TS arm just a little it lite.Rocky
Chrysler Firepower
Re: No left brake light? need help. [Re: Yellow Fever] #1636530
06/21/14 10:47 PM
06/21/14 10:47 PM
illinois
illinois
Nope nothing with the turn signal either. Nothing
Re: No left brake light? need help. [Re: bigblk66_coronet] #1636531
06/21/14 11:00 PM
06/21/14 11:00 PM
Take off the dr kick panel & seperate the pull apart electrical connector & see if you have fire at the wire for the dr brakelight ( www.mymopar.com has the colors). If yes work rearward for the open. If no, seperate the dangling pull apart connector under the steering col for the brakes/turn signals & checking the half for the TS harness, with the stalk in nuetral there should be continuity between the white wire which is the hot in from the brake pedal switch and the 2 "out" wires that go to the left/right large (brake/ts) filaments respectively in the rear bulbs. That'd be a start
Re: No left brake light? need help. [Re: RapidRobert] #1636532
06/22/14 12:06 AM
06/22/14 12:06 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Commonly , this is a turn signal switch problem... do all the easy and free stuff first..
Also try feeding 12V to the proper wire at the kick panel disconnect, to see if it works with a jumper wire.
Re: No left brake light? need help. [Re: sthemi] #1636533
06/22/14 12:22 AM
06/22/14 12:22 AM
BDW Online content
BDW  Online Content
This might help
