Re: Voltage Drop on RR 440
[Re: 454Baja]
#1636418
06/21/14 02:21 PM
06/21/14 02:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Your excessive draw at cranking is called the starter.
5v at the coil in run is semi-normal, what is the voltage at the feed end of the ballast? It should darn near be battery voltage, if not find out why.
[Re: Supercuda]
#1636420
06/21/14 03:03 PM
06/21/14 03:03 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
A weak battery will cause the drop also.Typically I like to see at least 12.6 at the battrey with no power on.Rocky
Chrysler Firepower
[Re: Supercuda]
#1636423
06/21/14 10:09 PM
06/21/14 10:09 PM
therocks
Niles , Ohio
If the battery drops to 9 volts its either the starter which should be pulling a huge amp.Or the battery is weak.The key wont have much to do with the 9 volts at the battery.Like I said 12.3 at the battery with no draw is marginal.I like to see at least 12.6.Rocky
Chrysler Firepower
[Re: therocks]
#1636424
06/21/14 11:04 PM
06/21/14 11:04 PM
Supercuda
About to go away
About to go away
up yours
if he has 12.3v at the battery and 8 at the ballast, in run, then his problem is not the battery.
[Re: Supercuda]
#1636425
06/21/14 11:28 PM
06/21/14 11:28 PM
RapidRobert
I would sub in a known good/fully charged batt (if there's any doubt of its' condition). If the starter cranks fast enough to start it then the starting circuit is fine and if it does start when cranked then the ign system is good & being fed enough to fire it. I wouldn't sweat what you get for readings with the key on (eng off) & concentrate on what you get for running (charging) voltage at a fast idle at the power source (the alt) and the storage device (the batt) & if those ain't right then clean connections/terminals till you find/correct the high resistance (voltage drop) that's keepin it from being right . Your VOM is your friend
