Re: 360 and 5.7 crank pics
[Re: MR_P_BODY]
#1636331
06/21/14 07:25 PM
06/21/14 07:25 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I think I would always use a Wix racing filter.. they dont filter the smaller partials BUT they also by pass sooner which would supply oil at all times... JMO
I would eliminate the filter mounting point and take out some 90 deg angles too.
Matt
[Re: MattW]
#1636332
06/21/14 07:26 PM
06/21/14 07:26 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Sorry, it's hard to be descriptive without really seeing. Are the #2 & #4 mains drilled straight through from one side to the other, as in "I can see straight through the crank."? Next question is are #2 & #4 mains drilled twice(hole every 90 degrees) or once (hole every 180 degrees)? From what I can see in the pics, the holes are only drilled once, and are what I would consider "out of time" with the crank throws. This is mot likely why the mains are half grooved. You would probably be best off drilling the holes in the correct timed position, and plugging the holes as mr p described.
[Re: TRENDZ]
#1636333
06/21/14 07:30 PM
06/21/14 07:30 PM
MattW
Ontario Canada
Getting pick up soon. Cooking supper
[Re: MattW]
#1636337
10/13/14 05:27 PM
10/13/14 05:27 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
is this only on the 5.7 cranks or 6.1 and 6.4 also?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: MattW]
#1636338
10/13/14 06:47 PM
10/13/14 06:47 PM
Posts: 3,415 Toronto
mshred
Toronto
for Mrshred
Thanks Matt! I have the same question as Ray, would this be the same for the 6.1 and 6.4 cranks also?
Either way, look forward to what you and Jesse find out
[Re: sixpackgut]
#1636339
10/13/14 06:51 PM
10/13/14 06:51 PM
MattW
Ontario Canada
I have a 6.1 crank also I'll take a look.
[Re: MattW]
#1636341
10/19/14 11:54 AM
10/19/14 11:54 AM
MattW
Ontario Canada
They changed the oiling holes on the 6.4. Gone are the holes straight through the crankshaft. Wonder why? Matt 5.7
Re: 360 ,5.7 crank and 6.4 pics UPDATE
[Re: MattW]
#1636342
10/19/14 11:55 AM
10/19/14 11:55 AM
MattW
Ontario Canada
6.4
