Re: A500 rebuild thrust shim question
[Re: convx4]
#1636303
06/21/14 05:12 PM
06/21/14 05:12 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Between the input shaft and the intermediate shaft there is a selective thickness thrust washer and a thin steel thrust plate (fits on the pilot hub of the intermediate shaft), the thrust plate often gets omitted when the trans is reassembled. If the thrust plate is missing it will account for your loose end play, if the plate is there and you have the thinnest selective washer you can lose about .020" with the thickest washer.
