79 dodge dually ignition key wont return #1635571
06/19/14 04:01 AM
06/19/14 04:01 AM
Nashport, OH
chargers777 Offline OP
Nashport, OH
when I let off the key nwhen it starts it wont return.The starter keeps grinding.It feels like the keys switch is binding.What do I check?How do I get the ignition switch out?
Re: 79 dodge dually ignition key wont return [Re: chargers777] #1635572
06/20/14 02:35 AM
06/20/14 02:35 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Does it have a tilt column? Tilt & standard are different critters and require different processes to replace the Ignition switch.
If its a tilt, make sure the activation rod is not dragging on the column at the bottom of the dash. The switch is on the column, under the dash, and a rod goes up through the column to the lock assembly. Gene
Re: 79 dodge dually ignition key wont return [Re: poorboy] #1635573
06/20/14 03:18 AM
06/20/14 03:18 AM
Nashport, OH
Nashport, OH
non tilt column
Re: 79 dodge dually ignition key wont return [Re: chargers777] #1635574
06/20/14 02:41 PM
06/20/14 02:41 PM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
You pull the stearing wheel off,
there is a clip inside,
that holds the ignition in,
and a pig tail of wires that unplug.
I think there is a spring that makes the key return..
Re: 79 dodge dually ignition key wont return [Re: scannman70] #1635575
06/20/14 02:47 PM
06/20/14 02:47 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The spring is in the switch itself, not the cylinder-lock assem. I wonder if the cylinder is binding and can be helped with some spray stuff. Never seen the switch spring back action fail.
Re: 79 dodge dually ignition key wont return [Re: buildanother] #1635576
06/21/14 04:22 AM
06/21/14 04:22 AM
Nashport, OH
Nashport, OH
I syrayed wd 40 in it and it didnt help.
Re: 79 dodge dually ignition key wont return [Re: chargers777] #1635577
06/22/14 02:19 AM
06/22/14 02:19 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
replace the switch
Re: 79 dodge dually ignition key wont return [Re: Mr_fixit] #1635578
06/23/14 03:54 AM
06/23/14 03:54 AM
Nashport, OH
Nashport, OH
How do I get the switch out?
Re: 79 dodge dually ignition key wont return [Re: chargers777] #1635579
06/23/14 02:15 PM
06/23/14 02:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 79 dodge dually ignition key wont return [Re: stumpy] #1635580
06/25/14 12:04 AM
06/25/14 12:04 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Is there a second page to that Allpar article? If there is how do you get to it, as everything I tride led to an add.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: 79 dodge dually ignition key wont return [Re: shinnery] #1635581
06/25/14 03:27 PM
06/25/14 03:27 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Looks like a one page deal. This is the part you will be interested in.
After you disassemble the column to this point, you will then press in on the "A" button, and the ignition switch will slide out.
Then you can remove the switch itself.
Re: 79 dodge dually ignition key wont return [Re: hp383] #1635582
06/25/14 03:32 PM
06/25/14 03:32 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
If you happen to have a tilt column, there may be a rod that runs to a remote ignition switch located farther down the column. Its been a long time since I have opened up a 70's tilt column so my memory is a bit hazy.
