Re: 1972 challenger front rotor torque?
[Re: Shoet1]
#1635486
06/18/14 09:22 PM
06/18/14 09:22 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
I torque all the wheels except the truck to either 90 or 100.Even with the Pro Stars they go to 90.Did it at work also.If mags good to recheck after say 10 miles or so.Rocky
Chrysler Firepower
[Re: Shoet1]
#1635489
06/18/14 10:08 PM
06/18/14 10:08 PM
Challenger 1
Cincinnati, Ohio
Yes, it is the one big spindle nut, I read twenty ft lbs, then back off 90 degrees and hand tighten after that until the cotter pin goes in. Thoughts?
You read it wrong.
I have to look in my service manual for the pre load, but you want need some pre load which is more than hand tight.
Put it together and spin the rotor by hand while you snug the spindle nut with socket and rachet, one knoch past tight is when the cotter pin goes in.
[Re: Shoet1]
#1635490
06/18/14 10:10 PM
06/18/14 10:10 PM
Posts: 4,848 Memphis
HemiRick
Memphis
That procedure sounds right the 20 ft lbs is to seat any new bearings. Then back off to loose, and tighten till the slack is just out, in use the assembly heats up and everything expands making the fit tighter.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
