Dying dashboard pad? #1634741
06/17/14 12:39 AM
06/17/14 12:39 AM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Is there any other way to dye this pad while still in the car other than spray black dye? Such as a small sponge dipped in black dye and applied very lightly to surface of crash bad. Is it possible to do and have a decent finish? Thanks, Dave
Re: Dying dashboard pad? [Re: superbeedave] #1634742
06/17/14 10:46 PM
06/17/14 10:46 PM
MO
cdp Offline
cdp  Offline
MO
I've heard of people using Ritz dye for seat belts. May work for dash pad, but I doubt you'd get "show quality" results. Just a thought.
Re: Dying dashboard pad? [Re: superbeedave] #1634743
06/18/14 10:29 AM
06/18/14 10:29 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
No! You can mask it off and then clean it with laquer thinner and then shoot it.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Dying dashboard pad? [Re: MOPARMIKE69] #1634744
06/18/14 01:30 PM
06/18/14 01:30 PM
Cincinnati, Ohio
Cincinnati, Ohio
That's what I thought I would have to do. It will take longer to mask it all off then it will to spray it. Can't get overspray anywhere inside the car. Thanks, Dave
Re: Dying dashboard pad? [Re: superbeedave] #1634745
06/18/14 03:04 PM
06/18/14 03:04 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I always take longer to mask off than to paint.
Shouldn't be that bad, look at the way I masked off the entire car to shoot the cross piece of the radiator support with a paint gun.You could do it in less than an hour and spray bomb has way less overspray than a gun.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Dying dashboard pad? [Re: MOPARMIKE69] #1634746
06/18/14 10:14 PM
06/18/14 10:14 PM
Cincinnati, Ohio
Cincinnati, Ohio
How true! I'm guilty of that also!!
