Re: HEMI Woes
[Re: mattsmopars]
#1634660
06/16/14 10:00 PM
06/16/14 10:00 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
I assume it has a hydraulic cam if its a 70. But a solid cam motor will behave that way if the lash is way to tight. Also check the float levels.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: HEMI Woes
[Re: mattsmopars]
#1634661
06/16/14 10:56 PM
06/16/14 10:56 PM
Posts: 1,913 central P.A.
HEMIDOG 70
central P.A.
Have you checked the length of the fuel pump push rod? Might look at it to see if it has failed on the end and worn down. I had a friend a couple years back that had a similar issue as you describe almost like a vapor lock issue and it was his fuel pump push rod. It just took him a while to find it. Good luck! Matt
Check this if it is a Mopar performance rod. Hughes Engines sells a hardened fuel pump pushrod. Mine was chewed up in under 1000 miles. A pic of the old and the new Hughes rod.
Re: HEMI Woes
[Re: ScottSmith_Harms]
#1634665
06/17/14 01:14 AM
06/17/14 01:14 AM
Posts: 5,164 CT
GTX MATT
CT
Sounds like ignition, change the condensor and change or clean the points if its a point ignition. If not check for a leaking coil.
Re: HEMI Woes
[Re: Paul G]
#1634667
06/17/14 01:10 PM
06/17/14 01:10 PM
RapidRobert
original point setup correct? (1) coil or ballast (got spares you can sub in one at a time for a quick test?) (2) block all (4) metering rod pistons up so you're on the power circuit and take it out again for a quick test (vac leak)
