318 engine build
#163461
12/06/08 08:16 PM
12/06/08 08:16 PM
Posts: 4,463 Rome, PA
Ryan_340
Rome, PA
I am building a 318 for my 72 Power Wagon short bed truck. I will be running 35" tires and 4.56 gears, and the NP 435 4 spd. trans. Heres is my current build so far, the shortblock-
1971 318 block bored .030" over stock crank polished and balanced 340 floating rods 340 windage tray Federal Mogul STL-285NP30 pistons, sitting at zero deck. Crane powermax .454"/.480 lift cam.
I need help picking what heads and intake I should use? Thanks for any suggestions!
I have a set of #587 340/350 heads w/ 1.88 intake valves and gasket-match porting, these a freshly rebuilt with a 3-angle valve job. And I have a stock set of 318 #302 casting heads that need rebuilt.
1972 Power Wagon W100
1973 Power Wagon W200
1971 Duster
1972 Dart Swinger
3-1972 Demons
Re: 318 engine build
[Re: Ryan_340]
#163462
12/06/08 08:35 PM
12/06/08 08:35 PM
RapidRobert
my suggestion sell the 587's, rebuild & use the 302's with a head gasket to get you .035-.040" quench.
[Re: GoodysGotaCuda]
#163464
12/06/08 09:07 PM
12/06/08 09:07 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'd use a set of EQ Magnums, or the 302s.
[Re: moper]
#163465
12/08/08 08:57 AM
12/08/08 08:57 AM
Posts: 15,487 Florida
scratchnfotraction
#302 heads with 188/160 valves with the bowls cleaned up used a couple sets this way with a home clean up of the bowls used a set on my 360 in the 4x4 also,lots of low end,runs out of steam about 5500 rpms though
