modern tech analysis 1965 426 Hemi
#1634349
06/16/14 12:26 PM
06/16/14 12:26 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
my apologies if this has been posted before http://www.auto-scape.com/?p=305this a very technical report that uses many modern engineering terms, but is worth struggling through and studying the many graphs that compare the 426 to more modern engine designs like the 5.7 Hemi
Re: modern tech analysis 1965 426 Hemi
[Re: PJ68RT]
#1634351
06/16/14 02:20 PM
06/16/14 02:20 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
Can someone please provide a summary?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1634352
06/16/14 02:28 PM
06/16/14 02:28 PM
Posts: 5,163 CT
GTX MATT
CT
It’s obvious that Chrysler engineers in the 1960s knew what they were doing and , as indicated, this wasn’t necessarily the case with their period peers.
Its not as efficient as some modern engines but the legend lives on. The ports flow well and have good filling capacity for the engine, they're pretty efficient, combustion efficiency isn't up to snuff with some modern engines but likely wasn't a concern at the time, the cam has slow ramps. They took a venture into analyzing the ports from a standpoint other than the flow rate at 28" of water, and tried to look at it from more practical standpoints of their capacity to fill the engine, which is good.
It seems that they didn't offer a true conclusion though?
[Re: GTX MATT]
#1634353
06/16/14 02:48 PM
06/16/14 02:48 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
I was more intrigued by the comparison between the 906 and LS-1 heads. Looks like Ma Mopar knew quite a lot back then.
[Re: 360view]
#1634355
06/16/14 10:53 PM
06/16/14 10:53 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
there is a reason im not an engineer.... the old girl comes off pretty well considering it took what, 3 or 4 months of development to get it to Daytona? all in all, not too shabby for a 50 year old design vs the new stuff.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: 360view]
#1634357
06/16/14 11:26 PM
06/16/14 11:26 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I haven't read the entire article, but the first statistic they state is wrong, Mopar did NOT finish 1, 2,3, & 4 at the 1964 Daytona 500.
[Re: 360view]
#1634358
06/17/14 12:51 AM
06/17/14 12:51 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Thanks for posting the link & even though its a technical read, it shows ma mopar & the Hemi boys knew what they were doing. What I thought was really informative was how the Gen 3 dual plug design helps offset any deficiency in its swirl characteristics. Modern roller cam ramp design, dual plugs & 2.2 rod journal stroker kits makes the Elephant King Kong again...
[Re: 360view]
#1634362
06/18/14 12:36 PM
06/18/14 12:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I had to do a lot of similar test when I was working at Chrysler and seen a lot of grafts of similar data.. but that was part of my job... back then it was a lot of fun when we could do R&D.. once Daimler took over that pretty much ended... as to what is meant by lab exhaust.. that depended on the test being run.. maybe a header but most were with manifolds with pipe extensions without muffs... if headers were to be run I ended up building most of them
