Re: 2001 Jeep issues - "NO BUS" message
[Re: olemopar]
#163420
12/06/08 11:51 PM
12/06/08 11:51 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Pat, the pcm and body computer, and instrument panel is not comm. with each other, unplug the inst. panel amd then see if it will start, could be that , pcm or bcm,or crank sensor or cam sensor,unplug each one at a time and see if the no buss goes away Thad
I was fortunate enough to find some information on checking the crankshaft position sensor to make sure it wasn't shot. Turns out I had some pretty low resistance where there should have been none.
Found a parts house around the corner that had one in stock ($107) and had it swapped out in an hour. Worst part of the whole operation was trying to reach it way up on the bellhousing from under the truck.
Thanks for your help, felluhs.
