Re: Goodyear Slick PSI ? [Re: Quicktree] #1634002
06/16/14 02:27 PM
06/16/14 02:27 PM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
So longer wouldn't have helped?
I guess I need some tutoring!?!?!?
I am glad this is just for fun!
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1634003
06/16/14 06:20 PM
06/16/14 06:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Mark
I doubt it, looked like it hooked to me. get a close up video of the right rear tire at launch.
Re: Goodyear Slick PSI ? [Re: Quicktree] #1634004
06/16/14 07:36 PM
06/16/14 07:36 PM
Mt. Eden Ky.
Mt. Eden Ky.
Mark
Hmmmm........ I will try. Getting good video has been a problem.
I guess I was looking for the 60 ft time to be lower, given the ET and MPH ? So I guess it is making the ET we have, from the MPH, and not so much the 60 ft time? It doesn't match the estimating programs, very well.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1634005
06/16/14 08:05 PM
06/16/14 08:05 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
To get a better 60ft I think you need a lower gear and or more stall.
My D50 weights the same as yours with a pump gas small block and my best 60 has been a 1.33. It is 1.34 most of the time. Mine is stock leaf springs and home made caltrak bars, 4.56 gears , 5400 8 in.PTC convertor and 315/60 M/T Drag Radials.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1634006
06/16/14 08:09 PM
06/16/14 08:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Mark
Mark
thats because your combo is off, start with the converter. thats what i would do
Re: Goodyear Slick PSI ? [Re: Quicktree] #1634007
06/16/14 08:57 PM
06/16/14 08:57 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I run 10psi and my 60ft's is 1.38-1.42 never tried anything else
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Goodyear Slick PSI ? [Re: D-50] #1634008
06/16/14 10:28 PM
06/16/14 10:28 PM
Mt. Eden Ky.
Mt. Eden Ky.
I had PTC build the converter for the car. They had all the specs. I guess either they set it up for 1/4 mile, or the fact that I said street/ strip changed the plan. I thought it was a 4500 converter until I called them last week for a recommendation on launch RPM. When he looked at my order he said 3500-4000. I agree it could use more gear probably higher stall, but the engine is "mild" and probably making good torque at 4,000!?!?
Does your D50 have a trans brake? Do you spray it at launch?
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1634009
06/16/14 10:33 PM
06/16/14 10:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I bet you put a 5600 8" converter in that thing and pick up at least a .10
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1634010
06/16/14 10:38 PM
06/16/14 10:38 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mark
I am foot braking it and it is NA. I am thinking of spraying it in the near future.
Re: Goodyear Slick PSI ? [Re: Quicktree] #1634011
06/16/14 10:56 PM
06/16/14 10:56 PM
Mt. Eden Ky.
Mt. Eden Ky.
That would be nice! Are you taking into consideration it is a 727 trans and not a Power Glide?
I just thought of something. When I ordered the converter I thought the car was going to be a lot lighter. I scewed the program!
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: D-50] #1634012
06/16/14 10:59 PM
06/16/14 10:59 PM
Mt. Eden Ky.
Mt. Eden Ky.
I think you have it running strong as is then.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Quicktree] #1634013
06/17/14 09:50 AM
06/17/14 09:50 AM
Mt. Eden Ky.
Mt. Eden Ky.
I know that this is probably true, but I am not willing to put the time and money into a converter swap right now. I have some carb and intake combos I want to experiment with, to try and extract more power.
Changing the converter means laying on the floor. Changing the carbs and intake I can do standing!
I don't do the floor work so well these days.
Mark
1996 Ram 1500 Sport
1968 road runner
