Goodyear Slick PSI ? #1633982
06/15/14 02:18 PM
06/15/14 02:18 PM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
I am running the Goodyear 14-31-15 slicks on 15X15
rims. The car is about 2950 with driver.
I called Goodyear and they said to run 6.5 to 7 psi. in the tires. I have run them as low as 8 psi and they handle OK on top end.
It just sounds a little low @ 6.5 to 7 lbs.
Anyone else run them that low at a comparrible weight?
We are trying to improve the 60 ft. times.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1633983
06/15/14 02:21 PM
06/15/14 02:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
run mine at 8.5
Re: Goodyear Slick PSI ? [Re: Quicktree] #1633984
06/15/14 03:01 PM
06/15/14 03:01 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If it dead hooks @ 8 lbs no need to go lower.The only reason to go lower is if its spinning the tires.As for 60' times they will always be better with as high of air pressure as you can run with out spinning the tires.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Goodyear Slick PSI ? [Re: MRMOPAR622] #1633985
06/15/14 03:10 PM
06/15/14 03:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've tried dropping to 6.5 from my normal 7.5-8.0 and it felt squirmy at the top end letting off; didn't improve 60' or ET so I went back to 7.5-8.0.
Your deal may well be different; my car's a 3000-lb low-10s footbrake 368CI SB/904 Duster running 13x31 Goodyears on 15x12 Flys. I've run up to 10PSI but it leaves & ETs better (6000 stall) @ 7.5-8.0.
Re: Goodyear Slick PSI ? [Re: MRMOPAR622] #1633986
06/15/14 03:12 PM
06/15/14 03:12 PM
I had a set of goodyear 16x33x15 on a set of 15 inch wide wheels, it would hook from 9.0 (I never tried higher) to 7.0 and o straight. I pulled them off, they where on the car before I bought it for over 6 yrs so I switch to a set of M/T 14x3`x15 stiff walls, I started of running them at 9.0 to 8.5 lbs, I have tried 12 lbs at the loacl track and it spun, I run 10.0 in them now on a bad track I advise new racers to pump the tires up until it stars to spin and the 60 fts. slow down and then go the other way on lower pressure until it slows down, make your decsion on what you like
Re: Goodyear Slick PSI ? [Re: Cab_Burge] #1633987
06/15/14 03:21 PM
06/15/14 03:21 PM
Mt. Eden Ky.
Mt. Eden Ky.
Well it seemed to hook the best it has so far, in the way it carried the front wheels up further down the track. But the 60 ft. is still not that good?
Tuning the engine is picking up the MPH but the 60 ft. doesn't seem to improve much.
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1633988
06/15/14 03:30 PM
06/15/14 03:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you may be at a point where tire pressure isn't going to help your 60' especially in the heat of the summer, try shock adjustment etc
Re: Goodyear Slick PSI ? [Re: Quicktree] #1633989
06/15/14 03:33 PM
06/15/14 03:33 PM
Mt. Eden Ky.
Mt. Eden Ky.
Is this a converter and gearing issue, rather than tires?
The converter is 3500 to 4,000 and the gear is 4.11. This is a street strip compromise.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Cab_Burge] #1633990
06/15/14 04:05 PM
06/15/14 04:05 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Goodyear Slick PSI ? [Re: W.I.N. Racing] #1633991
06/15/14 04:22 PM
06/15/14 04:22 PM
Mt. Eden Ky.
Mt. Eden Ky.
This is pretty much what I have done. I started at 10 psi. It was spinning a lot.
I had the car scaled because it was pulling right. First pass after scaling was at 9 psi was 1.40 60 ft.
We went to 8 psi, after I talked to Goodyear last week and the 60 ft. dropped to 1.38.
It doesn't seem to be spinning now, but I don't have the video in my possession yet to evaluate it.
A minor jet change picked up the mph.
I am not a chassis tuner at all.
I am trying to get into the 5 second ET range. I guess I can just keep tuning the engine for more power?
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1633992
06/15/14 07:07 PM
06/15/14 07:07 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Just a heads up,,,make SURE you are getting in the "tracks" or the "groove" at the starting line. Knowing your car from pics here, I imagine the rear is pretty narrow. You may be getting one wheel alittle bit off from run to run, causing the 60' to vary. DAMHIK
If you like drag racing, support your local track.
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1633993
06/15/14 07:51 PM
06/15/14 07:51 PM
Lehigh Acres, Florida
rickstershemi Offline
Mark
IMO you need more stall 5k-6k and maybe 4.30's
Rickster
Re: Goodyear Slick PSI ? [Re: rickstershemi] #1633994
06/15/14 08:10 PM
06/15/14 08:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Mark
Rickster
stall way to low for a good 60'
Re: Goodyear Slick PSI ? [Re: Quicktree] #1633995
06/15/14 08:47 PM
06/15/14 08:47 PM
Mt. Eden Ky.
Mt. Eden Ky.
Mark
Rickster
Ok....Well it is a street / strip / Hot Rod, so I may have to try and make the 5. sec ET number with more power!? I think that is doable!? The car doesn't have spool either. And as you probably guessed no trans brake.
It seems to want more fuel..... I have a Dominator carb to try as well.
I appreciate the input Guys!
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: CHAPPER] #1633996
06/15/14 09:33 PM
06/15/14 09:33 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I second that.
Re: Goodyear Slick PSI ? [Re: dartman366] #1633997
06/15/14 10:19 PM
06/15/14 10:19 PM
Mt. Eden Ky.
Mt. Eden Ky.
I second that.
I know this is true, as it has already happened. The guy in the starting line booth has helped me the last two times out! It is very much appreciated, as I seem to place the car poorly on my own!
Thanks!!
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1633998
06/15/14 10:36 PM
06/15/14 10:36 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I second that.
Thanks!!
Mark
I run exactly the same slick and pretty equal weight and I found that on a well prepped track mine likes 12.5 psi but on a not so well prepped I have to reduce the pressure, I was at my home track and they usually aren't as well prepped especially on T@T night and my first pass @12.5 it spun some, my second I reduce pressure to 12.0 and that helped but needed to go down a little more, but I broke a tranny and wasn't able to accomplish that.
Re: Goodyear Slick PSI ? [Re: dartman366] #1633999
06/15/14 11:28 PM
06/15/14 11:28 PM
Mt. Eden Ky.
Mt. Eden Ky.
Sorry to hear about your tranny.
I only run on T&T nights for now as the car is not dialed in and the driver is worse!
I guess right now I am just an "ET chaser". If I stay at these speeds I will of course have to get my license.
From what you are telling me , it sounds like if my shocks were dialed in better, I could possibly run more air in the slicks?
It really doesn't drive bad at all now. I am just happy that it is going straight !
Thanks!
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1634000
06/16/14 01:11 PM
06/16/14 01:11 PM
Mt. Eden Ky.
Mt. Eden Ky.
Well, I have the video on U Tube. The burnout was worse than I thought.:o I can't expect a good 60 ft. on that burnout.
Here is the link.
https://www.youtube.com/watch?v=veIVKlb_N-U&feature=em-upload_owner#action=share
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Goodyear Slick PSI ? [Re: Hemi Allstate] #1634001
06/16/14 01:41 PM
06/16/14 01:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
looked fine to me, it carried the front wheels
