multirib [surpintine belt] pulleys ?? #1633950
06/15/14 10:53 AM
06/15/14 10:53 AM
moparx Offline OP
moparx  Offline OP
is there any multi-ribbed steel water pump and crank pulleys that are close to the same size as the corresponding pulleys on a big block ? this is a custom install, so spacing and bolt patterns can be off a little. not looking for a surpintine belt kit, just some pulleys to run in the conventional way. as always, thanks in advance.
Re: multirib [surpintine belt] pulleys ?? [Re: moparx] #1633951
06/15/14 02:08 PM
06/15/14 02:08 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
We use the magnum parts in our kits. Water pump you will run into a problem because all modern ones run on the backside of the belt.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: multirib [surpintine belt] pulleys ?? [Re: Jerry] #1633952
06/15/14 11:10 PM
06/15/14 11:10 PM
moparx Offline OP
moparx  Offline OP
that's what I was afraid of.......
Re: multirib [surpintine belt] pulleys ?? [Re: moparx] #1633953
06/16/14 01:10 AM
06/16/14 01:10 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
why do you want to go multirib without getting all the benefits? we try and keep our kits economical with a few different options. heck if you need we can custom machine a miltirib water pump pulley for you.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: multirib [surpintine belt] pulleys ?? [Re: Jerry] #1633954
06/16/14 11:32 PM
06/16/14 11:32 PM
moparx Offline OP
moparx  Offline OP
I understand the benefits of a surpintine system, but in this install, such a system will be too "cluttered" in appearance. the reason for a multirib belt is the belt "wrap around" of the pulleys may not be enough for the belt[v style] to function without slipping. your systems are very nice pieces, so please do not take offence.
