lower control arm question - 68 runner #1633712
06/14/14 07:51 PM
06/14/14 07:51 PM
Petaluma, CA
JimDiesel Offline OP
Petaluma, CA
I cant seem to find any info on this in my manual.
Do the lower control arm pivot shafts take any grease where the go into the k frame?
68 Road Runner
67 Coronet
Re: lower control arm question - 68 runner [Re: JimDiesel] #1633713
06/14/14 08:03 PM
06/14/14 08:03 PM
Tho I 've never had a tapered LCA shaft rust up/be difficult to remove which is surprising (compared to UCA's ) I do wipe em with a thin coat of chassis grease as it is bare metal & I feel it should be protected like any other metal & doing it causes no harm
Re: lower control arm question - 68 runner [Re: RapidRobert] #1633714
06/14/14 11:34 PM
06/14/14 11:34 PM
Petaluma, CA
Petaluma, CA
Thank you.
I didn't want to have to take this back apart tomorrow for lack of grease.
68 Road Runner
67 Coronet
