Page 1 of 3 1 2 3
Swap 3.23 to 3.55 rear end... Is it worth it? #1633515
06/14/14 02:37 PM
06/14/14 02:37 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
I want a little more torque from takeoff and thought about swapping my 3.23 sure grip for a set of 3.55 sure grip gears. I have also thought about putting the lower gear set into my 904. Thinking I might do one or both. How much highway speed driving will I sacrifice if I do the 3.55? Will it really benefit me much? Is it worth the swap? I can get a complete unit for $600. I figure I can sell my 3.23 set to pretty much absorb most of the cost.
I also have access to a set of 3.91 gears buy figure those would kill me at cruising speed. I have a 73 challenger with moderately built 69 340 with Edelbrock heads, Voodoo cam, about 10:1 compression. I have 15 inch wheels if that helps.
I am pretty sure I am going to do the 904 gear swap. I have a spare transmission and will do the swap and rebuild myself. Anyone do it? Is it worth it? Gearset and rebuild kit will cost me about $275... Not too bad to me if it gives me some extra torque on takeoff.
That's King Weenie to you!
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Telvis] #1633516
06/14/14 02:50 PM
06/14/14 02:50 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
try this out:
http://vexer.com/automotive-tools/speed-rpm-calculator
according to this you'll lose just over 400rpms
worth it? yes.
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Telvis] #1633517
06/14/14 03:00 PM
06/14/14 03:00 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
What engine? What torque converter do you have? If you have a stock converter, a swap to a good converter could be worth several tenths. Way bigger improvement than the gear swap you are considering. The 904 low gear set seems to be worth about a tenth on this site. The 3.23 to 3.55 swap might be worth a couple tenths. Just speculating here. Very application specific of course. IMO, the closer the converter is to being optimum for your combo, the less difference a small gear change will make.
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: dangina] #1633518
06/14/14 03:02 PM
06/14/14 03:02 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
What about the 3.91 gears? The tool says about 700 rpm....seems like a lot to me...
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: forphorty] #1633519
06/14/14 03:05 PM
06/14/14 03:05 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Agreed 100%. I went from 3.23's to 3.91's and it made little difference at the track. More fun around town though.
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: forphorty] #1633520
06/14/14 03:07 PM
06/14/14 03:07 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
I was looking to get a different converter. I spoke with a guy at Turbo Action and he recommended the 904 lower gear set as a priority over a converter change. He said a converter would help but the lower gears and a converter would really help. He acted as though the gears were a better way to spend the money. He said the lower gear set would give me equivalent of a 3.60 gear in 1st. I have a TCI converter I got with the 904 when I bought it. I don't know the stall speed on it. Nothing wrong with the tranny and the converter seems to work fine. I just want more torque on takeoff.
I have a 73 challenger with moderately built 69 340, .030 over, Forged SpeedPro pistons with Edelbrock 60179 heads, Voodoo cam 60402, about 10:1 compression. I have 15 inch wheels.
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Telvis] #1633521
06/14/14 03:19 PM
06/14/14 03:19 PM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
I have 3.23s with a 9.5 inch SMR converter in my small block challenger, the 3500 stall speed is a little high with the 3.23s on the freeway. It flashes back and forth. I am going to rebuild my spare sure grip chunk with 3.91s. I just don't think going to 3.55s would be worth it. I'd go lower. Maybe 3.73s
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: FuryBoy] #1633522
06/14/14 03:47 PM
06/14/14 03:47 PM
I could see where 3.23's and 15" tires ain't giving you the low end you'd like. the 904 low gear would be going from a 2.45 to a 2.74 so your first gear overall ratio would be 8.85 (2.74X3.23) as opposed to 7.91 (2.45x3.23) plus I think 2nd gear might be a bit lower with the low gear set also but I ain't sure on that. I would make sure the eng is tuned right including the adv curve with a dual plane intake and the right carb then consider what guys have posted on more in depth changes. If you ain't out on the interstate alot I dont see a problem with 3.91's even. going from a 3.23 to a 3.55 is going to up the RPM's ~10% in all gears and the 904 low gearset is gonna up you ~12% in low gear. Just me I'd go with the low gear set plus a top notch converter if I took the trans out plus 3:55's plus super tune the eng & the components on it EDIT Along with the low gear/better tc, a 3.73 742 clutch sure grip would be my hands down wish list. I had 4:10's with 14" tires in my first Mopar in 1975, a 440 GTX 4 sp convertible & that was toooo low. The next year I drove it to California & that was back when the speed limit was still 70
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: RapidRobert] #1633523
06/14/14 04:12 PM
06/14/14 04:12 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I would change to the 3.55 and put the low first gear in the 904, you may also want to try bring the total timing in a little faster.
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Telvis] #1633524
06/14/14 04:18 PM
06/14/14 04:18 PM
Central TX
roe Offline
roe  Offline
Central TX
I think you'll be surprised by the low gear set. In my sig car I had my trans rebuilt with a low gear set and the Transgo TF-2 shift kit, and even with the 2.76 peg leg, takeoff was noticeably better. Now I'm working on getting my hands on a 3.23 suregrip to go with the low gear set.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Darryls-Demon] #1633525
06/14/14 04:37 PM
06/14/14 04:37 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
My distributor is curved nicely and timing is good. I have spent a ton of time getting just right. Don't think there is much if any room for improvement there.
Like I said I have easy access to the 3:55 or the 3:91 sets. The 3.73 are a bit difficult to find it seems. When you do see then they are really expensive. I could get the 3:91 set cheap because a friend has them. I will replace the torque converter with a Turbo Action when I do the 904 gear change. I just ordered the new gear set from A and A today. I am so tempted to do the 3:91 gears but I am afraid I won't be able to drive on the interstate. I don't do it much but when I do its 30 to 40 miles at a pop.
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Darryls-Demon] #1633526
06/14/14 04:39 PM
06/14/14 04:39 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
My common sense tells me this is the best thing to do. I think you are probably spot on.
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Telvis] #1633527
06/14/14 05:51 PM
06/14/14 05:51 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Ever considered going with an overdrive transmission and have best of both worlds?
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: BigBlockMopar] #1633528
06/14/14 06:04 PM
06/14/14 06:04 PM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
30-40 miles isn't to far. Put taller tires out back with 3.91s
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: BigBlockMopar] #1633529
06/14/14 06:30 PM
06/14/14 06:30 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
Thought about it but seems like a PITA to do.
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: FuryBoy] #1633530
06/14/14 06:35 PM
06/14/14 06:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
3.91s on a driver is a bad idea. It's even worse if you're used to driving around with 3.23s. You keep waiting for the transmission to shift into a higher gear it doesn't have.
I punted my 4.30s long ago. I hated those things. It made a drag racer very happy that I swapped straight across for his 3.23 set.
I've thought about doing a 3.55 in the Imperial to help it get around town but I will ONLY do that after an overdrive swap.
- Stu Harmon
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: feets] #1633531
06/14/14 06:53 PM
06/14/14 06:53 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
So you think even the 3:55 gears will be a pain on the highway? Maybe I should just do the transmission gear swap and keep the 3:23 gears. Man, this is a tough decision...
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Telvis] #1633532
06/14/14 07:08 PM
06/14/14 07:08 PM
3:55's are 10% deeper than the 3.23's you have now. Put a piece of stock across the top of one of your rear tires and measure down to the ground then borrow a pair of 14" wheels/tires from a buddy for a day that are 90% as tall as your current 15's & take it out for a highway spin & you'll know how the 3:55's are gonna feel. If all good then borrow some shorter ones yet & see if 3:91's sound like a plan EDIT & if the ones you borrow ain't exactly 90% just do the math & see what you get & measure their height for this after you get em on the car/down on the ground
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: RapidRobert] #1633533
06/14/14 07:18 PM
06/14/14 07:18 PM
Nanaimo, BC
N
NOrrTH Offline
NOrrTH  Offline
N
Nanaimo, BC
I have 3:55's on my GTX, stock converter and 295 50 15's. Im on the highway a fair bit and its fine to me. im considering going to 3:73's. Any higher with my size tire would suck on the highway. 3:55's are about as high as you'd wanna go imo. My Challenger had 4:10's and that was horrible. People passing you looking at you funny because you are struggling at 50ish. No thanks.
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: Swap 3.23 to 3.55 rear end... Is it worth it? [Re: Telvis] #1633534
06/14/14 07:38 PM
06/14/14 07:38 PM
The Netherlands
The Netherlands
Removing a tranny, opening it up and changing only first gear and installing it again seems about the same PITA to me as just installing an overdrive transmission and do some remodelling on the transmission tunnel.
Especially on an already smallblock car imo it would be a no-brainer to fab an A500 under it and end up with a car that's much more fun to drive. Instead of trying to find a compromise in fixed gearratio's.
I installed an A518 (OD+LU) in my '73 Dart and everyday I'm enjoying the fact there's an (almost) 5-speed transmission in the car and still have 3.91 gears in the rearaxle.
Page 1 of 3 1 2 3
