Need thread sealant on intake manifold vacuum port? #163342
12/06/08 04:18 PM
12/06/08 04:18 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
My slant6 intake manifold has a vacuum port fitting that screws into it. Do I need to use any type of thread sealant on it? If so, what do you recommend? I have regular plumbing pipe dope, but I don't think it's high-temp resistant. Thanks for any advice.
Roger
Re: Need thread sealant on intake manifold vacuum port? [Re: Fab64] #163343
12/06/08 04:35 PM
12/06/08 04:35 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Plumbers paste will work fine. Teflon tape does the same job and is less messy, but make sure you wrap it in the right direction so it doesn't bunch up when you thread it in.
Re: Need thread sealant on intake manifold vacuum port? [Re: Fab64] #163344
12/06/08 04:36 PM
12/06/08 04:36 PM
Kirkland, Washington
Pacnorthcuda Offline
It would probably be just fine without, but better practice would be use sealant.
Teflon Tape, or Thread sealant(liquid) or RTV or Permatex....almost anything would work.
Re: Need thread sealant on intake manifold vacuum port? [Re: Pacnorthcuda] #163345
12/06/08 07:42 PM
12/06/08 07:42 PM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
Teflon thread sealant would be best,
usually in a tube, cheap and will never leak.
I like it much beter than the tape!
Good luck!
Ed
Re: Need thread sealant on intake manifold vacuum port? [Re: SRT8Challenger] #163346
12/06/08 09:07 PM
12/06/08 09:07 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I use anti-sieze compound and it works well.
