Did a bonehead move installing Steering column #1633136
06/13/14 06:11 PM
06/13/14 06:11 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Installing the steering column and shaft on a 72 Roadrunner...Was having some difficulty with the end where the spring loaded blocks go into the steering pot...I put the nut on where the steering wheel goes and tapped it a little to put into place then had a lapse of judgement and whacked it...Well the steering shaft collapsed down...I went ahead and finished installing the column collars and put the star wheel with the roll pin so i can situate where there input shaft has to be...I looked on the steering box side...I need to extend it 6" now I am assuming I have to remove the column (as one piece) and whack the end section til it slides out...or is there another method...also...thinking back...I think there are two pins which hold the two steering shaft section in place...I am guessing I broke those.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Did a bonehead move installing Steering column [Re: Pyper70] #1633137
06/13/14 06:25 PM
06/13/14 06:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Try just pulling the shaft from the bottom - may take some effort but it should slide back out. I wouldn't worry about the pins, they just serve to hold the shaft extended - probably for ease of fitment on the assembly line. If you're anal about the pins then you could probably find the correct diameter nylon or UHMW to make new ones but I wouldn't bother.
Re: Did a bonehead move installing Steering column [Re: Stanton] #1633138
06/13/14 06:30 PM
06/13/14 06:30 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Clamp a pair of vise grips to the shaft and tap on them to extend the shaft. You haven't hurt anything because the pins are just plastic and are not a safety factor.
