Which timing pointer #1633127
06/13/14 02:27 PM
06/13/14 02:27 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
When running a Jesel belt drive and MSD crank trigger.
The milo don one doesn't work.
Re: Which timing pointer [Re: Sammy] #1633128
06/13/14 03:15 PM
06/13/14 03:15 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Assuming you are running an ATI balancer, this one is my favorite. But you need to buy the balancer from him so the triggers will be in the correct location. Notice no crank trigger wheel. I like that.
http://hemimilitia.com/pge2.html
If you like the old way. You can get this from Mancini or Mazzolini.
http://arengineering.com/products/crank-trigger-kit/
2011 Drag Pak Challenger
Re: Which timing pointer [Re: rickseeman] #1633129
06/13/14 10:17 PM
06/13/14 10:17 PM
AndyF Offline
AndyF  Offline
I sell a version that works with an ATI damper that has the magnets in the damper. FHO is the only dealer that orders the integral style.
The AR177K is the least expensive solution for the Mopar wheel size. I use the Chevy wheel on my engine since I have the Chevy bolt pattern on the damper. I make pickups for both Mopar and Chevy wheels.
Re: Which timing pointer [Re: AndyF] #1633130
06/13/14 10:41 PM
06/13/14 10:41 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I modified a stock one from a chrome cover.
Re: Which timing pointer [Re: Bigcube] #1633131
06/13/14 10:46 PM
06/13/14 10:46 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Little better pic..
Re: Which timing pointer [Re: Bigcube] #1633132
06/14/14 01:14 AM
06/14/14 01:14 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I used a big block Chev one I got on Ebay for cheap......it's mounted to the motor plate and seems to work O.K.
The options for a small block are really limited and this was plan B , but it worked.
