Street/Strip pump gas 440 #1633058
06/13/14 11:17 AM
06/13/14 11:17 AM
Northern Indiana
Dunnuck Racing Offline OP
Northern Indiana
Over the winter I took my brother's 440 from a stock bottom end 440 that had stock Edelbrock heads and a custom solid flat tappet cam, and went through it for some major upgrades.
I'm going to post up some before and after results here to highlight some of what we did.
Keith
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633059
06/13/14 11:29 AM
06/13/14 11:29 AM
Northern Indiana
Northern Indiana
The original combination included a Holley Street Dominator intake, and a Proform 950 carburetor that we had gone through. A Firecore distributor was added to provide spark from the Accel Digital ignition.
Running through a 727 with a Turbo Action10" convertor, 4.10 gears and Coltrane, the 3800 pound Satellite ran a best of 12.11 @ Norwalk last fall.
Hmmmm, cant get any pictures to load right now. Guess I'll come back to this later,......
Keith
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633060
06/13/14 12:00 PM
06/13/14 12:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
SOunds like fun...
Coming soon!!!!
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633061
06/13/14 12:07 PM
06/13/14 12:07 PM
Northern Indiana
Northern Indiana
Before tearing the old engine down, we made a few pulls on the Superflow to get a baseline for the upgrades.
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633062
06/13/14 12:13 PM
06/13/14 12:13 PM
an8sec70cuda Offline
Was the bottom end of this motor tired or just have real low compression pistons? Seems like it should have run better than a 12.11.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Street/Strip pump gas 440 [Re: an8sec70cuda] #1633063
06/13/14 12:26 PM
06/13/14 12:26 PM
Northern Indiana
Northern Indiana
When the Edelbrock heads went on, the decision was made to put too big of a header on. Scott bought 2" Super Comps planning for the future. We knew they would hurt the torque curve.
The convertor stalled to 3800 in his car.
Re: Street/Strip pump gas 440 [Re: an8sec70cuda] #1633064
06/13/14 10:56 PM
06/13/14 10:56 PM
Northern Indiana
Northern Indiana
I felt the 3800 lb. car should have run 11.80's if the hole in the torque curve wasn't there.
Actually the car was pretty low compression but it impressed a lot of people for a completely stock bottom end.
Keith
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633065
06/13/14 11:17 PM
06/13/14 11:17 PM
Northern Indiana
Northern Indiana
The engine made a tick over 500 horsepower and 540 lbs-ft torque on the as raced tune.
After tearing into it, I found a couple of scored cylinders, and a couple of rod bearings on their way south.
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633066
06/13/14 11:22 PM
06/13/14 11:22 PM
Northern Indiana
Northern Indiana
The new build was planned , parts ordered, etc. Scott asked me if I could get 650 horsepower on pump gas for him. I probably laughed at that . I told him I could port his heads and build a nice short block, New cam to go with it, better intake, etc. And get a little over 600 on pump gas.
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633067
06/13/14 11:33 PM
06/13/14 11:33 PM
Northern Indiana
Northern Indiana
I have been using Race Tec pistons and ordered a set with a small dome. I didn't want to cut the heads a ton to get decent compression.
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633068
06/13/14 11:47 PM
06/13/14 11:47 PM
Northern Indiana
Northern Indiana
The block was decked square, bored and diamond honed .020, New cam bearings, etc.
A fresh factory forged crankshaft was scrounged up due to the old one being a welded on remanufactured piece of questionable quality.
I assembled the shortblock with fairly tight bearing clearances, wanting to use a modern thinner oil .
Rings were file fit , 1/16, 1/16, 3/16 with moly tops and a Napier cut scraper second and installed on Eagle H beam rods
Re: Street/Strip pump gas 440 [Re: an8sec70cuda] #1633069
06/14/14 08:38 AM
06/14/14 08:38 AM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
Actually both... The compression before was 8.9 to 1. When I originally overhauled this motor (about 14 years ago) it was built with used parts from several different motors... It was the preverbial 509 cam motor until 3 yrs ago when we put the RPM heads and solid cam in it.
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Street/Strip pump gas 440 [Re: QTR MILR] #1633070
06/14/14 09:15 AM
06/14/14 09:15 AM
Q
Quicktree Offline
Quicktree  Offline
Q
get on with the story already
Re: Street/Strip pump gas 440 [Re: Quicktree] #1633071
06/14/14 10:04 AM
06/14/14 10:04 AM
Northern Indiana
Northern Indiana
I ported his Edelbrock RPM heads and worked on getting them to flow well without having a large csa.
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633072
06/14/14 10:14 AM
06/14/14 10:14 AM
Northern Indiana
Northern Indiana
Before and after , best port on my bench,....
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633073
06/14/14 10:20 AM
06/14/14 10:20 AM
Northern Indiana
Northern Indiana
I also ported a new Victor intake to go with the heads,....
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633074
06/14/14 10:24 AM
06/14/14 10:24 AM
Northern Indiana
Northern Indiana
Victor plenum work
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633075
06/14/14 10:34 AM
06/14/14 10:34 AM
Northern Indiana
Northern Indiana
The final assembly,
I picked an old Ultradyne NF69 grind for it along with Crane gold 1.6 rockers. Final compression after minor chamber clean up to the heads is 11.2 to one. With the large cam and aluminum heads it will run on e10 93 octane easily.
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633076
06/14/14 10:53 AM
06/14/14 10:53 AM
Northern Indiana
Northern Indiana
I'll try to finish posting later tonight. Just had a customer call and have to go make a housecall and help him out,...
Re: Street/Strip pump gas 440 [Re: Dunnuck Racing] #1633077
06/14/14 11:51 PM
06/14/14 11:51 PM
Northern Indiana
Northern Indiana
New combination compared to his old one,....
