RB intake install. Valley pan alone, or gaskets too? #1632493
06/12/14 12:56 PM
06/12/14 12:56 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
hey guys it's been several years since I changed RB intake manifold gaskets.
do I use just the valley pan or do I also need to use side gaskets.
If I remember back to my youth, I would normally just use the valley pan. in fact it wasn't until I first installed a tunnel ram back in 1999 that I can even remember seeing side gaskets included in the valley pan box.
I will be installing aluminum intake if that makes a difference.
Re: RB intake install. Valley pan alone, or gaskets too? [Re: hp383] #1632494
06/12/14 01:24 PM
06/12/14 01:24 PM
People have used the pan with and without gaskets and with and without sealer. (1) mockup & check that the intake/head interface angles are machined correct. (2) mockup the intake and valley pan & check the bolt hole/port height match. I use Permatex #1 on iron intakes and #2 on alum intakes, a thin wide swath around each of the 8 port holes in the metal valley pan on both sides. "superperformance" on here offers thin .015" fiber gaskets for reasonable money & Felpro has thick ones that come with the valley pan at your parts house.
Re: RB intake install. Valley pan alone, or gaskets too? [Re: RapidRobert] #1632495
06/12/14 01:32 PM
06/12/14 01:32 PM
Georgia
Steve Bryant Offline
Georgia
For my recent 440 build, we used a new valley pan and sealer only.
Re: RB intake install. Valley pan alone, or gaskets too? [Re: Steve Bryant] #1632496
06/12/14 01:49 PM
06/12/14 01:49 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Just the valley pan unless there is a reason to need something more to seal it.
On my engine the ports were bigger than the valley pan, so I had to grind the valley pan to fit. I was worried that I had to grind some of it pretty thin in some spots, so I glued the paper gaskets to each side for some extra insurance.
Re: RB intake install. Valley pan alone, or gaskets too? [Re: GTX MATT] #1632497
06/12/14 01:56 PM
06/12/14 01:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Have just used the pan and nothing else since the 60s.I do use a dab of RTV in the 4 corners and a bit where the hold downs go.Thats it and never any problems.Rocky
Chrysler Firepower
Re: RB intake install. Valley pan alone, or gaskets too? [Re: therocks] #1632498
06/12/14 03:58 PM
06/12/14 03:58 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Thanks guys thats what I was remembering. Although I do recall one intake, a CH4B i think it was, that I had to use two fiber gaskets on each side to get holes to line up.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
