Page 1 of 3 1 2 3
W8'ing is the hardest part.... It's alive! #1632443
06/12/14 11:43 AM
06/12/14 11:43 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
It's been a long time coming.... we'll load up and head to IMM in Indio in the am and put the finishing touches on this lil block and dyno it with it's new pipes. Finally seeing the light at the end of an incredibly long tunnel....
Re: W8'ing is the hardest part.... [Re: J_BODY] #1632444
06/12/14 11:52 AM
06/12/14 11:52 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Yep,
A bunch of work for 15 more HP than the W5 mill..., but I guess if the water stays where it belongs, it will be worth it!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: W8'ing is the hardest part.... [Re: MoparBilly] #1632445
06/12/14 12:01 PM
06/12/14 12:01 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
"W8'ing is the hardest part" I got a laugh out of your play on words, clever.
Good luck with your motor!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: W8'ing is the hardest part.... [Re: Hemi_Joel] #1632446
06/12/14 02:18 PM
06/12/14 02:18 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
good luck and went will we see ya again in Vegas with new motor...
Tony
70 AARCuda Vitamin C
Re: W8'ing is the hardest part.... [Re: 70AARcuda] #1632447
06/12/14 02:40 PM
06/12/14 02:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Bout time!!!
Re: W8'ing is the hardest part.... [Re: Al_Alguire] #1632448
06/12/14 03:01 PM
06/12/14 03:01 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
good luck
Re: W8'ing is the hardest part.... [Re: MoparBilly] #1632449
06/12/14 05:39 PM
06/12/14 05:39 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Yep,
I would hope it makes more than a max effort 650hp w5 does.
Re: W8'ing is the hardest part.... [Re: fishy340] #1632450
06/12/14 06:14 PM
06/12/14 06:14 PM
Renton Washington
Triple Threat Offline
Renton Washington
Let me know if I need to fly in and drive
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: W8'ing is the hardest part.... [Re: Triple Threat] #1632451
06/12/14 06:22 PM
06/12/14 06:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I thought about it, if I were starting from scratch I might try it. but for the few extra HP over my indy 1s just not worth it.
Re: W8'ing is the hardest part.... [Re: J_BODY] #1632452
06/12/14 09:36 PM
06/12/14 09:36 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: W8'ing is the hardest part.... [Re: fishy340] #1632453
06/12/14 09:43 PM
06/12/14 09:43 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep,
Max effort W5 mill can make WAY more than 650. I say that because the one in my ex car made well over 700 on the Dyno and backed it up at the track by going 140 at 3200 pounds and change on S/S springs and a 28 by 10 Dot tire.
That all said, heck yes...W8 has much, much more potential
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: W8'ing is the hardest part.... [Re: B3422W5] #1632454
06/12/14 10:01 PM
06/12/14 10:01 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Looks like the headers came out real nice Jay, merge collectors? what size are they?
Re: W8'ing is the hardest part.... [Re: Darryls-Demon] #1632455
06/12/14 10:18 PM
06/12/14 10:18 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Did you have Greg Holman make them?
[img] [/img]
Re: W8'ing is the hardest part.... [Re: clonestocker] #1632456
06/12/14 10:53 PM
06/12/14 10:53 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Yes Matt.... Gregg did his one day magic once again. 2, 2 1/8, 3 1/2 and will start with some bullet mufflers, but plan in the long run to put more exhaust on it. Honestly... we're leaving quite a bit on the table, but should put down some decent power and live a long happy life... of course we tried that route with the W5 crap and ended up pulling it apart all the time anyways Brett shot me a good deal on the top end, so we started building around it. Do I know what I'm doing? Nope!
Re: W8'ing is the hardest part.... [Re: J_BODY] #1632457
06/12/14 10:58 PM
06/12/14 10:58 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks good, can't wait to hear the numbers.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: W8'ing is the hardest part.... [Re: 1967dartgt] #1632458
06/12/14 11:45 PM
06/12/14 11:45 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Good luck with it Jay
Re: W8'ing is the hardest part.... [Re: B3422W5] #1632459
06/12/14 11:51 PM
06/12/14 11:51 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Not trying to piss ya off but 140 @ 3200 aint 700 brotha
Re: W8'ing is the hardest part.... [Re: fishy340] #1632460
06/13/14 12:44 AM
06/13/14 12:44 AM
Arizona
Chris'sBarracuda Offline
Arizona
That's funny, Wallace computes 703 HP without DA correction..
Chris..
Re: W8'ing is the hardest part.... [Re: Chris'sBarracuda] #1632461
06/13/14 10:36 AM
06/13/14 10:36 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Well if Wallace says so
Re: W8'ing is the hardest part.... [Re: J_BODY] #1632462
06/13/14 02:30 PM
06/13/14 02:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks like a nice stout small block you`ve got there..............
Page 1 of 3 1 2 3
