426 Hemi block #1631918
06/11/14 01:21 AM
06/11/14 01:21 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Does anyone know what is going on with Chrysler and the Gen 11 Hemi are they being produced by anyone . thanks
Re: 426 Hemi block [Re: robnbird] #1631919
06/11/14 12:17 PM
06/11/14 12:17 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Re: 426 Hemi block [Re: mr_340] #1631920
06/11/14 06:03 PM
06/11/14 06:03 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
thanks I will try him..
Re: 426 Hemi block [Re: robnbird] #1631921
06/11/14 06:31 PM
06/11/14 06:31 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
What is the difference between a "hemi" block and a regular RB block? I know about the cross bolts on the mains. Is that all or are there differences in the way the heads attach?
Just curious...
Re: 426 Hemi block [Re: Airwoofer] #1631922
06/11/14 07:33 PM
06/11/14 07:33 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Just curious...
A Hemi has bosses in the valley for additional head studs. Nuts are put on the studs from inside the valley. Here is a pic:
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 426 Hemi block [Re: Hemi_Joel] #1631923
06/11/14 07:41 PM
06/11/14 07:41 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Guys
World does not and will not have any iron blocks available.
aluminum yes.
Todd
Re: 426 Hemi block [Re: Hemi_Joel] #1631924
06/11/14 07:41 PM
06/11/14 07:41 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
A friend of mine has several 4.24 water blocks for sale 3500 ea these are the MoPar blocks. PM me if interested
Re: 426 Hemi block [Re: sasquatch] #1631925
06/11/14 09:07 PM
06/11/14 09:07 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Guys
aluminum yes.
Todd
I am curious as to why. Can you elaborate?
I have one and wonder if I should actually use it, now.
Master, again and still
Re: 426 Hemi block [Re: DaveRS23] #1631926
06/11/14 10:57 PM
06/11/14 10:57 PM
Addison,IL
OUTLAWSSAA Online content
OUTLAWSSAA  Online Content
Addison,IL
Guys
aluminum yes.
Todd
I talked to them at the PRI show. They said when Chrysler almost went into bankruptcy they took the molds back and that was that. He told me if I needed a block to walk over to the Bill Mitchell booth. So I walked over there and they told me all they were making was the aluminum blocks with no raised cam available.
Re: 426 Hemi block [Re: OUTLAWSSAA] #1631927
06/12/14 12:50 AM
06/12/14 12:50 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Yeah what he said. Do not worry about them, they are great blocks. Check your oil restrictor as some are not drilled. Easy fix in building not so much when assembled.
TOdd
Re: 426 Hemi block [Re: sasquatch] #1631928
06/12/14 11:15 AM
06/12/14 11:15 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Thank you!
Re: 426 Hemi block [Re: Handygun] #1631929
06/12/14 02:39 PM
06/12/14 02:39 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I'm guessing that's Tom.
I think he said he had 9 new pre World M/Perf blocks that he was planning on selling.
Re: 426 Hemi block [Re: SNK-EYZ] #1631930
06/12/14 03:04 PM
06/12/14 03:04 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
I don't think that will get you much detective work in this town Rich
Re: 426 Hemi block [Re: robnbird] #1631931
06/12/14 03:56 PM
06/12/14 03:56 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Good luck getting one in either CI or Aluminum right now. No new CI ones are available from anyone that I know of. The aluminum, you can order a KB or an Indy...but not a World block. I believe they are done with making them due to a contract issue with Mopar if I am not mistaken...
Re: 426 Hemi block [Re: Airwoofer] #1631932
06/12/14 03:59 PM
06/12/14 03:59 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Just curious...
The HEMI Block has 4 differences. #1,there are oil drain holes cast into each outside corner of the blocks (4 total) for the heads to drain the oil back into the pan. #2, the intake head bolt hole is cast further into the lifter gallery
#3, the push rods on a HEMI block are cast closer to the cylinder bore than on a wedge motor.
#4, And all Hemi blocks had 1/2 inch oil feed galleries.
That is it.
Old Geezer Racing
Re: 426 Hemi block [Re: sasquatch] #1631933
06/12/14 03:59 PM
06/12/14 03:59 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
TOdd
What is the oil restrictor?
Re: 426 Hemi block [Re: scatpacktom] #1631934
06/12/14 05:45 PM
06/12/14 05:45 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
TOdd
On the World block the oil passage to the heads is tapped and gets a restrictor screwed into it.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 426 Hemi block [Re: Hemi Allstate] #1631935
06/12/14 07:09 PM
06/12/14 07:09 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Re: 426 Hemi block [Re: scatpacktom] #1631936
06/14/14 09:09 AM
06/14/14 09:09 AM
mi
dirty magnum Offline
mi
world never made them . they paid world to use there name after all the problems with previous plant. mopar performance told me there waiting on x amount of orders to do another run
Re: 426 Hemi block [Re: robnbird] #1631937
06/14/14 09:46 AM
06/14/14 09:46 AM
Q
Quicktree Offline
Quicktree  Offline
Q
contact member 80arrow he has a complete mega block for sale I think,
