Now sounds like one time event, tendency to stall when clutch so perhaps not related to clutch depression at all. You mentioned heat soak and erratic idle and upon arriving home depressing clutch and engine appearing to want to stall.
Could be anything from mild vapor lock( unlikely unless really hot) to ethanol "enhanced fuel issue,,,very common on old carb powered cars,,,to old cars just being old cars and do what they do.,,,improper carb adjustment(fuel air mixture and or idle speed) timing, bad wiring somewhere in ignition system etc. Does car have AC?
Suggest to check this all out and note if and when occurs again,,,clutch depression incident could have been coincidental and sending you off in wrong direction for cause.
