Restoring tranny finish #1631154
06/09/14 07:50 PM
06/09/14 07:50 PM
Finally a HUSKER again
Moparnut426 Offline OP
I know these guys weren't painted, unless they were teal like some special HPP trucks, stuff like that,
With that said Im restoring/rebuilding the 727 for VETT1986's charger. Ive scrubbed it really well with soft wire brush, and solvent, then I used purple cleaner, and a light wheel acid and it came out pretty good, but up top, where you wont see it, there are some stains from some grease. I cant seem to get it off,
What are you guys using to clean the aluminum to look NEW cast looking?
Kasey
Re: Restoring tranny finish [Re: Moparnut426] #1631155
06/09/14 07:56 PM
06/09/14 07:56 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Try some Metyl Ethyl Ketone. That stuff will break up any grease. Do it in a very well ventilated area. I've used it on Harley engine and tranny cases with good results. You can get Kleen Strip brand substiute at Home Depot.
Re: Restoring tranny finish [Re: Pynzo] #1631156
06/09/14 09:59 PM
06/09/14 09:59 PM
Does it attack the aluminum
Re: Restoring tranny finish [Re: Moparnut426] #1631157
06/09/14 11:45 PM
06/09/14 11:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No it won't attack aluminum. Another good way to clean bare aluminum without harming the finish is soda blasting
Re: Restoring tranny finish [Re: ScottSmith_Harms] #1631158
06/10/14 02:42 AM
06/10/14 02:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: Restoring tranny finish [Re: kentj340] #1631159
06/10/14 02:55 AM
06/10/14 02:55 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Cheap DIY soda blaster:
http://www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
I used this DIY method on an aluminum distributor housing. It worked great, but I can't imagine trying it on a larger scale, like for a transmission.
Re: Restoring tranny finish [Re: CompSyn] #1631160
06/10/14 10:02 AM
06/10/14 10:02 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
What have folks been using on the aluminum afterwards to prevent oxidation? I'm concerned that a clear coat might yellow.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Restoring tranny finish [Re: FJR doc] #1631161
06/10/14 11:53 AM
06/10/14 11:53 AM
That's AWESOME!!
Ill be doing that.
Trannys almost done, so Ill put a plug in the tail shaft, tape all the holes up, and put an old converter in it, and go at it. I like that Idea~~
Re: Restoring tranny finish [Re: FJR doc] #1631162
06/10/14 11:28 PM
06/10/14 11:28 PM
I've been using RPM from ECS Automotive Concepts on all of my bare metal parts which seems to prevent oxidation with rust or the white crust oxidation that aluminum usually does. Great product!
http://www.ecsautomotive.com/rpm.php
Re: Restoring tranny finish [Re: ] #1631163
06/11/14 03:35 AM
06/11/14 03:35 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
as a soda blaster I can tell you that soda will not remove stains. at least my $10,000 blaster wont. soda isn't abrasive so it will not cut into the stain.
if its discolored before it will be after blasting. blocks wheels and trans cases allways come out the same with anything I have done.
Re: Restoring tranny finish [Re: chrisf] #1631164
06/11/14 10:18 AM
06/11/14 10:18 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Would a 2K clear satin finish hold up better on a transmission after it has been thoroughly cleaned?
Kevin
Re: Restoring tranny finish [Re: ] #1631165
06/11/14 12:46 PM
06/11/14 12:46 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I also used RPM. The surface still looks fresh after a year and a half.
Re: Restoring tranny finish [Re: dynorad] #1631166
06/11/14 12:51 PM
06/11/14 12:51 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I've used RPM on many other parts in my resto project. I'm sure that it will darken the aluminum color somewhat.
Kevin
Re: Restoring tranny finish [Re: FJR doc] #1631167
06/11/14 03:04 PM
06/11/14 03:04 PM
Ohio
billohio Offline
billohio  Offline
Ohio
I tried brake cleaner but had better results with oven cleaner.
I am also on my 2nd can of RPM
Re: Restoring tranny finish [Re: billohio] #1631168
06/13/14 07:51 PM
06/13/14 07:51 PM
Phoenix, AZ
MCTPhoenix Offline
MCTPhoenix  Offline
Phoenix, AZ
After you clean the surface, by glass beading or other means, try an adhesion promoter like Bulldog then flattened clear over it
Re: Restoring tranny finish [Re: Moparnut426] #1631169
06/14/14 03:51 PM
06/14/14 03:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Good luck with that, from my experience blasting media will get in somehow.
Re: Restoring tranny finish [Re: Moparnut426] #1631170
06/15/14 11:31 AM
06/15/14 11:31 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Cast paint
Re: Restoring tranny finish [Re: Moparnut426] #1631171
06/16/14 07:19 AM
06/16/14 07:19 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
If you want it perfect, these guys offer the service but is costly. Only for the most anal of us. Talk to Mark or Tom.
http://www.campbellautorestoration.com
Re: Restoring tranny finish [Re: John_Kunkel] #1631172
06/16/14 06:38 PM
06/16/14 06:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
