727 Band Adjustment Question #1631152
06/09/14 07:30 PM
06/09/14 07:30 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Adjusting the bands on a 727 in car.
External/kickdown adjusted just fine-normal.
Went to adjust low-reverse and almost runout of threads to get 72in-lbs.???
can`t say i`ve seen that before
Been a long time since i`ve done one.
Is the gear selector supposed to be in a certain gear?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 727 Band Adjustment Question [Re: 6bblFLASH] #1631153
06/09/14 08:14 PM
06/09/14 08:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Instead of using the turns out method, adjust so that you can pull the lever down about 1/4"-5/16" (measured at the servo piston) from the up position.
