Tunnelram RPM range
#1631139
06/09/14 07:14 PM
06/09/14 07:14 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
What is the Rpm range on this TR?
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Tunnelram RPM range
[Re: fed]
#1631140
06/09/14 07:26 PM
06/09/14 07:26 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
What is the RPM range on this TR?
It depends on the cam, carbs, headers, motor size and so on I would say from around 2500 RPM and up to where you want to shift it I've had a few motors with different tunnel rams, the carb. size, headers, cam and valve train will dictate where the motor will quit pulling hard Sorry for no personel experiences on that manifold ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Cab_Burge]
#1631141
06/09/14 07:59 PM
06/09/14 07:59 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
It looks like a weiand I run one of those years ago I think it was rated from 3500-7500.But like Cab said it is based more on your combo.I run 2 Holley 4779 750 DP with the air horns milled of and power valves block #80 sq jetted on a 440 cu n engine ported & polished 915 heads and Comp Cams 286 duration 750 lift.You will not lose any bottom end with that intake.Most engines similar to mine with a M1 intake a 1050 Holley made in the upper 580 hp range,with that intake mine made 614 hp @ 6400 RPM.Before the dyno pull they told me I should have went with the M1 & 1050 Holley,after the dyno pull they asked it they could try the intake & carbs on their personal engine and went from the upper 580 hp to 612 hp.The only thing the intake needs is gasket matching.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: AndyF]
#1631143
06/10/14 12:29 AM
06/10/14 12:29 AM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Porting them also helps with bigger short blocks, and obviously cam selection is important. I hogged mine out and saw a solid .10+ from increased runner volume on a 535 with 906 heads. It really woke up when I went from the .590 cam to a 286/286 @ .050 roller. The rpm difference was from 5700 best shift points to 6200 rpm with the roller.
[Re: Rob C]
#1631145
06/10/14 07:27 PM
06/10/14 07:27 PM
fed
Stockholm, Sweden
Sorry but i dont have enginespecs. I have the intake for sale and a customer asked. its not a Weiand but a Mopar intake.
[Re: Rob C]
#1631146
06/10/14 08:09 PM
06/10/14 08:09 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
How long are the runners on that MP part?
That will give you an idea of the power range, I'd take what's advertised with a grain of salt.
[Re: LSP]
#1631147
06/11/14 02:09 PM
06/11/14 02:09 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
FED, you can't listen to Chevy guys about a tunnel ram on a MOPAR, it's apples and oranges. On a big block MOPAR, the tunnel ram is more forgiving and makes more power than any single 4 intake. and more so when fitted with a pair of Dominators.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: fed]
#1631148
06/11/14 03:56 PM
06/11/14 03:56 PM
Posts: 792 Earth
Rob C
Earth
Sorry but i dont have enginespecs. I have the intake for sale and a customer asked. its not a Wheiand but a Mopar intake.
OK, then I'd tell him on a worked 440 it would be good for a range of 3000 - 8000. Then add a thousand for the short stroke engines.
(say "Why-And" LOL!)
[Re: Rob C]
#1631149
06/11/14 06:22 PM
06/11/14 06:22 PM
fed
Stockholm, Sweden
Thanks for the knowledge!
