Fuel tank builds pressure #1631101
06/09/14 05:40 PM
06/09/14 05:40 PM
Charleston, SC
safaritow Offline OP
Charleston, SC
I'm having trouble with my. 70 B body building pressure in the gas tank to the point were it pours fuel out the vent line. I have tried a new has cap (3) of them all vented. Ran a vent line up in my trunk big loops with 3/8 fuel line and back out still build pressure.
Help this is killing me.
Re: Fuel tank builds pressure [Re: safaritow] #1631102
06/09/14 10:16 PM
06/09/14 10:16 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I had a problem like that years ago on a brand X.
IIRC it was the fuel pump.
Re: Fuel tank builds pressure [Re: safaritow] #1631103
06/09/14 10:29 PM
06/09/14 10:29 PM
Yeah we're missing sumpin simple but I'm thinking either the tank is being heated (exhaust) or it's being pressurized (the pump as said). Here's a BTT for ya
Re: Fuel tank builds pressure [Re: RapidRobert] #1631104
06/09/14 11:28 PM
06/09/14 11:28 PM
Charleston, SC
Charleston, SC
3" TTI out the back and I'm running MSD Atomic but I was building pressure before the EFI.
Re: Fuel tank builds pressure [Re: safaritow] #1631105
06/10/14 12:00 AM
06/10/14 12:00 AM
IN
ahy Offline
ahy  Offline
IN
It sounds like the vent line at the tank may not be at the top. Maybe a defective tank or the vent is hooked up to the wrong fitting. A pic of the vent exit from the tank may help.
Also some '70's were "closed vent" with a can in the trunk to separate the vapor and fuel and a line to the engine for the vent. By chance was your's originally set up that way?
With vent installed it should not need a vented cap... and vented caps sold today hold a fair amount of pressure before they "vent" so the cap won't help.
