Re: How do roller rockers improve performance?
[Re: JohnRR]
#1631053
06/09/14 03:55 PM
06/09/14 03:55 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
Those rockers would improve performance because of the ratio change from what your current rockers are , CLAIMED 1.5 , to a claimed 1.6 , increase lift and duration without a cam change.
There is no real performance gain by just switching to a roller tipped rocker.
The quality of those rockers ???
Rockers arms are one place to not buy cheap Chinese junk . Ask those that bought off shore big block rockers because they were CHEAP , only to have them cause a dropped valve ...
Wow .. are those considered 'cheap'? $400+ ?
[Re: cal_gecko]
#1631054
06/09/14 03:58 PM
06/09/14 03:58 PM
Challenger 1
Cincinnati, Ohio
Friend of mine told me I should ditch the factory shaft-mounted rockers on my 360 (non-Magnum) and go with something like this: http://www.ebay.com/itm/PRW-SB-Mopar-273...30f&vxp=mtr
Said it would be a significant performance improvement. How does this improve performance?
For a LA SB I would stay with 1.5 rockers, with a good set of aftermarket 1.5s, your going to have more lift than from stock rockers and a little less friction.
I wouldn't call it significant even with 1.6 rockers.
[Re: autoxcuda]
#1631056
06/09/14 04:09 PM
06/09/14 04:09 PM
cal_gecko
Sacramento, CA
thanks guys.. AutoXCuda - good memory on the cam yeah... snowball effect is not what I need. I'll just drive it and enjoy it
[Re: cal_gecko]
#1631057
06/09/14 04:59 PM
06/09/14 04:59 PM
Posts: 27,477 So Cal
autoxcuda
So Cal
yeah... snowball effect is not what I need (MORE OF).
[Re: autoxcuda]
#1631060
06/09/14 05:10 PM
06/09/14 05:10 PM
cal_gecko
Sacramento, CA
[Re: autoxcuda]
#1631061
06/09/14 07:06 PM
06/09/14 07:06 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I didn't even open the link in the OP...
PRW...Chinese junk....don't grenade a motor for that stuff...I bought the 44 Source for $400 many moons ago and never installed em for fear of those exploding needle bearings...Why ditch a motor for a couple hundred bucks...I bought Harlands and it runs like a dream
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: JohnRR]
#1631063
06/09/14 08:56 PM
06/09/14 08:56 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Are U aware the PRW rockers are made in China... Most likely made from recycled Coors cans... The valve train is not a place to save $ buy the quality proven brands..
Just my $0.05...
[Re: DaytonaTurbo]
#1631064
06/09/14 10:42 PM
06/09/14 10:42 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
....often in the 1.4 range.....
And the number keeps getting lower.
[Re: BSB67]
#1631065
06/09/14 11:10 PM
06/09/14 11:10 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
In theory the roller has less drag to loosen up hp. How much. Maybe none. One good thing they do is put less wear on the valve guide since the roller will glide across the top of the valve easier and not put as much push on the valve to the side when opening. But if I was spending $400 or more dollars and looking for a performance gain I would not be buying roller rockers. Ron
[Re: 383man]
#1631067
06/09/14 11:15 PM
06/09/14 11:15 PM
Posts: 15,487 Omaha Ne
TJP
Omaha Ne
