How do roller rockers improve performance? #1631051
06/09/14 03:36 PM
06/09/14 03:36 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
Friend of mine told me I should ditch the factory shaft-mounted rockers on my 360 (non-Magnum) and go with something like this:
http://www.ebay.com/itm/PRW-SB-Mopar-273...30f&vxp=mtr
Said it would be a significant performance improvement. How does this improve performance?
Re: How do roller rockers improve performance? [Re: cal_gecko] #1631052
06/09/14 03:42 PM
06/09/14 03:42 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Those rockers would improve performance because of the ratio change from what your current rockers are , CLAIMED 1.5 , to a claimed 1.6 , increase lift and duration without a cam change.
There is no real performance gain by just switching to a roller tipped rocker.
The quality of those rockers ???
Rockers arms are one place to not buy cheap Chinese junk . Ask those that bought off shore big block rockers because they were CHEAP , only to have them cause a dropped valve ...
Re: How do roller rockers improve performance? [Re: JohnRR] #1631053
06/09/14 03:55 PM
06/09/14 03:55 PM
Sacramento, CA
Sacramento, CA
Wow .. are those considered 'cheap'? $400+ ?
Re: How do roller rockers improve performance? [Re: cal_gecko] #1631054
06/09/14 03:58 PM
06/09/14 03:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
For a LA SB I would stay with 1.5 rockers, with a good set of aftermarket 1.5s, your going to have more lift than from stock rockers and a little less friction.
I wouldn't call it significant even with 1.6 rockers.
Re: How do roller rockers improve performance? [Re: cal_gecko] #1631055
06/09/14 04:01 PM
06/09/14 04:01 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
IIRC, you have an comp XE-268 hyd cam.
I the performance increase per dollar spend is low. Better places to spend money.
Good chance you'll need new pushrods too. And those should be custom ordered to what you exactly need after checking with a pushrod measuring setup to see if what you have now is ok. S AKA: snow ball effect.
Re: How do roller rockers improve performance? [Re: autoxcuda] #1631056
06/09/14 04:09 PM
06/09/14 04:09 PM
Sacramento, CA
Sacramento, CA
thanks guys..
AutoXCuda - good memory on the cam
yeah... snowball effect is not what I need.
I'll just drive it and enjoy it
Re: How do roller rockers improve performance? [Re: cal_gecko] #1631057
06/09/14 04:59 PM
06/09/14 04:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
yeah... snowball effect is not what I need (MORE OF).
Re: How do roller rockers improve performance? [Re: cal_gecko] #1631058
06/09/14 05:02 PM
06/09/14 05:02 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
It is worth noting that recent high performance pushrod engines seem to be avoiding roller rockers.
Maybe the rollers make the rocker either too heavy or less stiff.
Recent rocker designs seem to emphasize lightness and stiffness, as do pushrods.
In the book "Chrysler Engines" former chief engineer Willem Weertman writes that roller hyd lifters improved the fuel economy of the Magnum upgrade series of engines, particularly the 3.9 V6 version.
Roller rockers are certainly not new.
Rudolf Diesel's original compression-ignition engine had a roller rocker.
Re: How do roller rockers improve performance? [Re: autoxcuda] #1631059
06/09/14 05:03 PM
06/09/14 05:03 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Reminds me of the old "Lit" song
Re: How do roller rockers improve performance? [Re: autoxcuda] #1631060
06/09/14 05:10 PM
06/09/14 05:10 PM
Sacramento, CA
Sacramento, CA
Re: How do roller rockers improve performance? [Re: autoxcuda] #1631061
06/09/14 07:06 PM
06/09/14 07:06 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I didn't even open the link in the OP...
PRW...Chinese junk....don't grenade a motor for that stuff...I bought the 44 Source for $400 many moons ago and never installed em for fear of those exploding needle bearings...Why ditch a motor for a couple hundred bucks...I bought Harlands and it runs like a dream
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: How do roller rockers improve performance? [Re: Pyper70] #1631062
06/09/14 07:55 PM
06/09/14 07:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
For your cam... a waste of money IMO. If you're running a solid cam or an aggressive hydraulic, then you need em. Yes there may be (very) slight gain because factory rockers often don't spec out to the true 1.5 ratio they are supposed to be, often in the 1.4 range. But that would be a terrible bang for buck upgrade in your case.
Re: How do roller rockers improve performance? [Re: JohnRR] #1631063
06/09/14 08:56 PM
06/09/14 08:56 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Are U aware the PRW rockers are made in China...
Most likely made from recycled Coors cans...
The valve train is not a place to save $ buy the quality proven brands..
Just my $0.05...
Re: How do roller rockers improve performance? [Re: DaytonaTurbo] #1631064
06/09/14 10:42 PM
06/09/14 10:42 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
....often in the 1.4 range.....
And the number keeps getting lower.
Re: How do roller rockers improve performance? [Re: BSB67] #1631065
06/09/14 11:10 PM
06/09/14 11:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
In theory the roller has less drag to loosen up hp. How much. Maybe none. One good thing they do is put less wear on the valve guide since the roller will glide across the top of the valve easier and not put as much push on the valve to the side when opening. But if I was spending $400 or more dollars and looking for a performance gain I would not be buying roller rockers. Ron
Re: How do roller rockers improve performance? [Re: BSB67] #1631066
06/09/14 11:13 PM
06/09/14 11:13 PM
IN
ahy Offline
ahy  Offline
IN
Agree the roller tip helps at higher lifts. It reduces "scrub" across the top of the valve. Rule of thumb over .5" orso lift. With a mild cam not much help.
If you push the cam or ratio up then you have to look at stiffer springs. With stiffer springs stiffer pushrods. As you say, it snowballs.
Re: How do roller rockers improve performance? [Re: 383man] #1631067
06/09/14 11:15 PM
06/09/14 11:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: How do roller rockers improve performance? [Re: TJP] #1631068
06/10/14 12:10 AM
06/10/14 12:10 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Here from one of the Mopar mags:
Re: How do roller rockers improve performance? [Re: MoparforLife] #1631069
06/10/14 02:35 AM
06/10/14 02:35 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
I remember reading an article years ago that stated that roller rockers were one of the BIGGEST money wasters in the average street engine...$400 (since that's the dollar figure floating around in this thread) will give you noticeable gains in the heads, but you'll likely never see it in the rockers.
They'll sure look purty, though!
2 Demons...no, not my kids!
Re: How do roller rockers improve performance? [Re: 4speeds4me] #1631070
06/10/14 02:45 AM
06/10/14 02:45 AM
Northern MN
cedarmachine Offline
Northern MN
If you think they are a "bolt on" part, you may be in for a surprise when the pushrods all hit the heads.
They move the pushrod seat towards the fulcrum to get the additional ratio. This usually leads to a clearance problem. Some guys bend up a few sets of pushrods before they figure this out.
