After market gauges draining battery #1630848
06/09/14 12:49 AM
06/09/14 12:49 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
72 Cuda with all new wiring. I put in an aux power distribution block that uses blade fuses. I power the block from the starter relay stud. I am running the MSD, fuel pump and after market gauges from here, and in the future a radio. The previous owner had run all of this stuff through the bulkhead connector and used the empty bat slot. The battery was always fine this way.
I ran a test light between the battery positive terminal and the battery cable and it was dimly lit. When I removed the blade fuse that powers the aftermarket gauges the light goes out. The gauges are wired the way they were before except for their power source.
Any idea why there would be a draw from these gauges with the setup that I have now?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: After market gauges draining battery [Re: cdstl] #1630849
06/09/14 01:01 AM
06/09/14 01:01 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need a switch to kill the power. What gauges are you running?
Re: After market gauges draining battery [Re: cdstl] #1630850
06/09/14 01:03 AM
06/09/14 01:03 AM
They ain't wired the way they were. As you know theyre hot all the time now which you cant have cuz it runs down the batt. You'd wanna power em from the ign1 switched 12V circuit source
Re: After market gauges draining battery [Re: RapidRobert] #1630851
06/09/14 01:33 AM
06/09/14 01:33 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Thanks Robert. I never thought it through when I ran them from the block. I think in the short term I can run them from the ACC slot on the bulkhead connector, does that sound like a problem? I don't have a factory radio and the previous owner powered the gauge and tach lights from the "light" slot in the radio plug and that's what I did again.
I guess that I need to run the aftermarket gauge power from the yellow mold as it is listed as ACC in the FSM. The red mold appears to be hot at all times since it powers the cigar lighter and glovebox light. I already have the standard gauge backlights and ashtray light in the orange mold. The console light is supposed to go in there too so that would fill it up.
Re: After market gauges draining battery [Re: cdstl] #1630852
06/09/14 02:33 AM
06/09/14 02:33 AM
I would T into the heaviest wire at the fuse block that is hot only with the key in the "on" position and T into before it hits the fuse in the fuse box that it is going to. Run that wire thru an inline fuse holder with a 20 amp fuse then to the gauges hot side then the other side of the gauge(s) goes out downstream to the sender(s). If there's an unused slot in the fuse block you could add a 20A glass fuse & use it for a more professional/less cluttered setup. EDIT you may want less than 20A on the fuse
Re: After market gauges draining battery [Re: cdstl] #1630853
06/09/14 11:22 AM
06/09/14 11:22 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If you have already wired it under the hood like that, I would just put relay contacts between starter relay post and the fuses you added. I would power the relay from Ignition 1.
Craig
