'01 Ram 1500 4x4, crooked steering wheel #1630084
06/07/14 06:53 PM
06/07/14 06:53 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
I've noticed my steering wheel is 15-20* left of center when driving straight down the road. The truck pulls very slightly right when going down a straight section of road. I'm not sure it's not the crown of the road pulling the truck right, it's minor. Should I be looking for something bent on the left side? I recently replaced the front axle U-joints, but I don't see how this would be involved?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: GO_Fish] #1630085
06/07/14 08:43 PM
06/07/14 08:43 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Check for a worn track bar and other steering components.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: GO_Fish] #1630086
06/08/14 12:43 AM
06/08/14 12:43 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
if you get a chance to get on the road when it's empty, cross over the centerline, and see if the pull is in the opposite direction. i find some roads really do pull me towards the shoulder in the truck, but not in the car.
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: GO_Fish] #1630087
06/08/14 11:26 AM
06/08/14 11:26 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
A friend of mine bought either a '99 or 2000 (can't remember) Ram "Off Road" truck brand new. It had the same symptoms (slight pull to the right), and he had back to the dealer several times. The tech's drove it and agreed that it had the right pull, but couldn't resolve it after probably 5 trips back. Eventually, he learned to ignore it. I bought my 2001 Ram 4X4 used in 2005...it has the same right pull. Soon after I bought it I put new tires on it and had them check the alignment. They said it was good, and that set of tires wore perfectly. I don't know... If you figure it out, please post the cure.
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: Fat_Mike] #1630088
06/08/14 04:56 PM
06/08/14 04:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
usually not a lot you can change on a straight axle front end, especially camber unless you go with offset ball joints. Caster and toe are the only adjustments available without extensive time involved. That said .25+ toe will provide a better driving experience on older ram trucks at the sacrifice of a little tire wear. Another thing to "try" is to swap the tires side/side and see if the pull changes. Might be a tire issue. Think my 2500 4x4 has a slight drift to the left iirc.... can't remember for sure, it's a truck and wears the tires great so it doesn't concern me.
...If you want the wheel straight loosen the adjuster sleave on the steering link from the pitman arm to the tie rod assy. Give it some twists with a channel lock and you can move the wheel. It won't affect toe setting.
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: J_BODY] #1630089
06/08/14 05:14 PM
06/08/14 05:14 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Crawled back under for a look at the track bar. Nothing screaming worn out, but driver side axle seal is now leaking, guess I buggered it pulling or installing the axle for the U-joints. Going back in, Uggh. I'm not so concerned about the slight drift to the right. More concerned about the wheel being crooked left, and what caused that. Truck has 71k on original factory non-greaseable fittings. Maybe time to get a bunch of Moog parts with zirk fittings everywhere, get an alignment and be done with it for 10 years.
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: GO_Fish] #1630090
06/08/14 09:03 PM
06/08/14 09:03 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
If all steering and suspension components are tight, then go have an alignment done, that will cure it,thing move slightly over years, needs to be adjusted. as the leaking axle seal go, not an easy back yard job, the left seal is next to the differential,( yes the ring gear, carrier assy needs to be removed), special tool to reach through the axle tube ( can make one with washers and LONG threaded rod,nuts) the right one is next to the axle actuator mid tube. again special tool.
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: moretoys] #1630091
06/08/14 10:58 PM
06/08/14 10:58 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Okay, I understand. Front axle U-joints were done on jack stands in my gravel driveway, and that tested my patience big time. Sounds like the seal replacements are going to be a trip to the shop. You are also correct, if an alignment alone will fix things, I can push the replacement track bar, tie rod ends and ball joints down the road a year or two.
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: GO_Fish] #1630092
06/12/14 02:19 AM
06/12/14 02:19 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
My 01 Off Road has the same pull to the right, nothing big, just annoying.
the drivers side axle seal also was leaking for the first few months after I did the seals, I left the gear lube level a half inch below the plug and it seems to have stopped leaking,even after topping off to the plug level...
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: sthemi] #1630093
06/12/14 10:40 PM
06/12/14 10:40 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
I thought about leaving the fluid level lower, leaking seal not a big deal unless the axle went under water. But then I thought maybe the carrier bearings were meant to be partially submerged, and might get hot with less oil. I also am thinking about adding some Lucas to try and swell the seals, but that may just be a waste.
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: GO_Fish] #1630094
06/14/14 08:46 PM
06/14/14 08:46 PM
Sandy, OR
DART67GT Offline
DART67GT  Offline
Sandy, OR
Odds are your axle seals are fine. It just puked out into the tube when you pulled the axles. I had the same issue with my 2000 Ram 2500 after a full front end rebuild. My steering was all over the place. Cause was mainly the steering box and track bar.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: DART67GT] #1630095
06/14/14 11:31 PM
06/14/14 11:31 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
That is a good point about spillover into the tube. I'll have to watch it for a bit and see if it continues or stops. Thanks for the heads up!
Re: '01 Ram 1500 4x4, crooked steering wheel [Re: GO_Fish] #1630096
06/20/14 12:35 AM
06/20/14 12:35 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
DART67GT is on it. Likely just some spilled out. Seals are pretty tough when axles are put back in.
