1994 Ram replacement rocker panels #1630074
06/07/14 05:40 PM
06/07/14 05:40 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Both of the outside rocker panels on my 1994 Ram are rusty and need replaced. Is there particular brand or company you would recommend or more importantly avoid purchasing them from?
This is a standard cab truck.
Thanks,
Re: 1994 Ram replacement rocker panels [Re: nd65] #1630075
06/08/14 12:39 PM
06/08/14 12:39 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I am not positive, but the ones I have seen in person at swap meets all appear to be the same. So I am assuming they are. I just bought a set for my '95 reg cab to do. only thing I noticed is they go past the factory seam where it meets the cab corner---if your cab corner and up to where it meets the rocker is ok, you could just trim it back some.
Outcast Dodge guy.
Re: 1994 Ram replacement rocker panels [Re: 85_Ram_4speed] #1630076
06/08/14 01:36 PM
06/08/14 01:36 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Yeah, the corners are fine so trimming is not a problem.
Thanks for the reply.
